So, is this $12 tool that they sell really worth it? It looks like a screwdriver with a bend in it to me. Anyone here make one, and if so, how did you do it?
My friend that got his '69 vert long before I did, asked the same question. Mad his own. If I recall correctly, he put it in a vise and heated with a propane torch, grabed it with some welding golves and bent it. Lossened the vice and cooled it in bucket of water. Only used it twice. Once on each door.
Someones doing alot of door work. I would imagine its not really quite worth ordering one. I would go for the make one myself action after I had already tried to mess with the door springs with various others out of my toolbox. But I am just not sure what it takes for that operation.
I just bent a cheap screwdriver in a vice, didn't need heat. I have a set of three that I made in various sizes for different jobs. (The small one is great for removing window crank handles.) I put a tiny reverse bend in the tip to keep the spring from slipping off. Joe
I had a broken spring, ordered a replacement and the "tool". You only need the tool for removal not installation. If your spring is broken like mine was, don't buy the tool.
I'm definitely not going to buy one. Probably going to find a couple old pos screwdrivers and make a couple with the torch and vise at work tomorrow. (fire! fire!) It sounds like I probably don't really need them anyway since my spring has long since broken (ask me about the 1/4" X 1/4" crack in the fiberglass on my door).
SIGNGUY, its called a "Door hinge spring installation tool" and you can find it in some of the catalogs like Zip, Eckler's, etc. Its $12.00 for apparently a $0.49 screwdriver that someone bent at the end. For me, a $12.00 screwdriver better have a vaccuum hose attached to it somewhere, if you know what I mean.
I fiddled with the spring for quite awhile before I said "screw it" and bought the tool. It is not only bent, but the end is curled to wrap around the spring. Once I had the tool it took me (10) minutes start to finish. You just drop the spring in the top holes, flex the spring with the tool on the underneath side, tap the sping into the lower holes with a hammer. It wasn't money badly spent, and I have lent to a few members of my club already, so I feel it has paid for itself.
