Getting the TPI bug
Old Dec 19, 2003 | 10:48 AM
SharkintheWoods's Avatar
SharkintheWoods
Default Getting the TPI bug
Easy question for you guys. Do I have to stick to pre 87 units to use on the perimeter bolt style heads?
Thanks.......
Old Dec 19, 2003 | 11:01 AM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Getting the TPI bug (SharkintheWoods)
no you can drill the center holes on angle for the bolts to line up,i have sportsman 2 heads and an 87 intake .
Old Dec 19, 2003 | 12:30 PM
markdtn's Avatar
markdtn
Default Re: Getting the TPI bug (patsnitrovette)
All Vette manifolds work with the older iron heads, F-body TPI intakes use the upright center bolts on 87 up. Either can be worked to fit with some drilling. F-body has the fuel lines come out on the drivers side and has a port for EGR. Corvette has fuel lines that come out on the passenger side and has an external port for EGR. There are other subtile differences, but these are the biggest manifold differences.
To Getting the TPI bug
