Turbo350 modulator question???
Old Dec 20, 2003 | 04:22 PM
comp's Avatar
comp
Default Turbo350 modulator question???
is there any difference between using the big or small dia. modulator, will
the larger one cause more line pressure or any thing else?????
Old Dec 21, 2003 | 12:20 AM
comp's Avatar
comp
Default Re: Turbo350 modulator question??? (comp)
no slush box guy's out there tonight? :sleep: :smash: :skep:
[Modified by comp, 8:59 AM 12/21/2003]
Old Dec 21, 2003 | 10:43 AM
jimtreber's Avatar
jimtreber
I've used both but I always bought the adjustable where available. I believe there is a set screw in the vacuum tube that can alter the shift points. Granted, not by much but it did add a little flexibility.
1976 406 TH400 3000stall, 4.11
Old Dec 21, 2003 | 11:13 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Turbo350 modulator question??? (jimtreber)
:iagree:
[Modified by BSeery, 8:13 AM 12/21/2003]
Old Dec 21, 2003 | 11:39 AM
comp's Avatar
comp
Default Re: Turbo350 modulator question??? (BSeery)
both of mine are adjustable, but it calls for a small on car & large on truck,
factory know's truck will get used harder i wondering if it raises the line to
help trans not to slip as much, none of my books has anything(i can find)
on the difference's just that you adjust for shift points and "firmness"???
Old Dec 22, 2003 | 07:18 AM
comp's Avatar
comp
trans. tech's come in on mon. mornin' :confused:
Old Dec 23, 2003 | 01:31 AM
comp's Avatar
comp
easier question does any body use the big one on their tranny? :skep:
Old Dec 23, 2003 | 04:33 PM
comp's Avatar
comp
brain finaly started workin' went to different site :hurray:
To Turbo350 modulator question???
