Anybody have this intake
Old Dec 20, 2003 | 05:28 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Anybody have this intake
Holley 300-36 Street dominator
Curious if anybody has one and if they make it fit. I know it will need a drop base. Its .02" taller in the back and .06" taller in the front than my Weiand 7546. I think I may need to get a shorter top plate to my intake manifold, cause its touching the hood.
Old Dec 20, 2003 | 05:50 PM
rainman69's Avatar
rainman69
Default Re: Anybody have this intake (Guru_4_hire)
Looks like a copy of the LT1 design. Also looks like the Weiand 3000 I have. My aircleaner rubs my hood with a dropbase and "stock" K&N filter.
Old Dec 20, 2003 | 06:12 PM
Guru_4_hire
Cruise-In V Veteran
Default Re: Anybody have this intake (rainman69)
So it would appear I need to find a slightly deeper drop base or an aircleaner lid that pops up less.
Old Dec 20, 2003 | 08:24 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I have an old Street Dominator. It's a single plane and about 1.25 inches higher than a stock SB manifold. I'm using a L-88/LT-1 drop base and a 3 inch element.
The SB hood closes completely. :yesnod:
Old Dec 20, 2003 | 11:18 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
GM's ZZ-4 intake is supposed to be a take-off of the early LT-1 only a little lower
This manifold is used on all ZZ series 350 HO engines and also can be used on all small-block Chevrolet's thru 1986. This aluminum manifold produces the same horsepower as the previous high-rise design, but provides increased hood clearance and more versatility. It has a dual-pattern flange that can accommodate both standard-flange Holley and spread-bore Quadrajet four-barrel carburetors. This manifold has provisions for all late-model accessory brackets, EGR (exhaust gas recirculation), and an integral hot air choke. A heat shield can be mounted underneath the manifold to prevent coking when EGR is used.
Technical Note: This manifold carburetor flange is approximately 1 /2 " lower than the LT1 manifold.
Jim
Old Dec 21, 2003 | 09:15 PM
SharkAttack's Avatar
SharkAttack
Correct. I had one of these on my previous Vette - 71 coupe with LT-1 hood and LT-1 air cleaner assembly (along with a host of other mods).
To Anybody have this intake
