Rust proofing the frame and inside the frame.
Old Dec 21, 2003 | 05:23 PM
bluebelVETTE's Avatar
bluebelVETTE
Default Rust proofing the frame and inside the frame.
What is the best way to rust proof a frame and inside the frame, and what type of rust remover and paint to use. :banghead:
Old Dec 21, 2003 | 06:14 PM
jpatrick636's Avatar
jpatrick636
Default Re: Rust proofing the frame and inside the frame. (bluebelVETTE)
I like Por 15. http://www.por15.com/
It can be sprayed so if you have the right equipment, you can get it in tight places. However, enless an area is subject to getting wet, you don't have to go crazy getting it into every nook and cranny. Also, with Por 15, the preparation is much less than products that cannot neutralize rust. Check it out.
Old Dec 21, 2003 | 06:25 PM
Spook's Avatar
Spook
Default Re: Rust proofing the frame and inside the frame. (jpatrick636)
I loved my usage of por15 as well. I am looking into getting a setup to spray it. I just painted it on the first time, wanted to see if it was worth it and I'll be darned if it isn't.
Old Dec 21, 2003 | 11:35 PM
bluebelVETTE
Default Re: Rust proofing the frame and inside the frame. (Spook)
I may use POR 15 for the outside, what you all think to spray oil inside the frame and the area I can't get to with POR 15? Atleast the oil helps to prevent rusting/repels water or keep away moisture.
That's what I do when I leave car parts outside I just coat it with oil or grease.
[Modified by bluebelVETTE, 4:35 AM 12/22/2003]
Old Dec 22, 2003 | 09:02 AM
Stewart's74's Avatar
Stewart's74
I know people who have used an ordinary garden sprayer to get the POR-15 into the frame. When finished, just throw the sprayer in the trash.
Old Dec 22, 2003 | 09:37 AM
NHvette's Avatar
NHvette
There is special wax/oil that is meant for inside frame protection. The solution
is pretty cheap ($25/gal or less) - but the spray equipment will cost ya.
My auto parts store had the stuff @ about $25 a gallon ... buy 4 gallons and
get the complete spray setup for $100. I shoulda bought it, since you can do
a lot of protecting for that $200 total.
I actually had my frame cut open, but chose NOT to POR15 it on the inside.
Trust me, I'm a POR15 nut, but I saw too much loose scale to warrant the
use of the POR15. I figured that I can always spray it later with the wax/oil
solution.
Good luck.
:seeya
[Modified by NHvette, 9:38 AM 12/22/2003]
To Rust proofing the frame and inside the frame.
