Q-jet on built engine...bad idea?
Old Dec 21, 2003 | 09:28 PM
Timbo2's Avatar
Timbo2
Default Q-jet on built engine...bad idea?
I got a Qjet, (rebuilt by Holley) that I bought for my 71 ... it works great when I stuck in on my 73 Camaro.. (which is for sale by the way)... but after getting the new 350 bored 30 over with a slight cam and double hump heads, the vette seems to be starving for gas. Did I screw up putting the Qjet on that engine, or is there some trick to making it work well on a slight "built" engine?
thanks,
TIm
Old Dec 21, 2003 | 09:40 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Q-jet on built engine...bad idea? (Timbo2)
Holley rebuilt Q-jets are notorious for poor performance. Holley does some goofy schit to the Q-jet, but a well tuned Q-jet will perform great on a 350.
Our resident Q-jet expert "Lars" has tuned a bunch of Q-jets for people here on the forum and they are usually very happy with the results.
He can also reverse the damage done by Holley rebuilds.
Drop him an email at V8FastCars@msn.com
He also has a number of articles out on http://www.corvettefaq.com on tuning the Q-jet.
Old Dec 22, 2003 | 09:04 AM
Stewart's74's Avatar
Stewart's74
Default Re: Q-jet on built engine...bad idea? (Smokehouse69)
Lars re-built my Q-jet and it rocks :thumbs:
Old Dec 22, 2003 | 10:37 AM
Wrencher's Avatar
Wrencher
I'm surprised Dep hasn't tuned in with his fix for a Q-jet: A large sledge hammer! :D
Hans
Old Dec 22, 2003 | 10:42 AM
Fevre's Avatar
Fevre
Sounds like a rejet/rerod is in order, if it was tuned for one eng of lower hp then it will prolly need some fine tuning when used on a higher hp eng.
Old Dec 22, 2003 | 04:36 PM
comp's Avatar
comp
Default Re: Q-jet on built engine...bad idea? (Fevre)
his bound to jump on this one ,,, his just layin' back awile i bet. :lolg: :lolg:
on the Q-jet workin' take a look at the NHRA stocker & super stock cars
done correctly they will rock..... :party:
Old Dec 22, 2003 | 07:40 PM
hermit's Avatar
hermit
Although it has been very popular to trash Q-jets I think that they are a very good alternative to the other carbs more commonly used. They have small primaries which helps keep low rpm velocity up. The seconaries are big enough to feed a healthy engine . And the metering system is very precise. The big trick is finding someone who knows how to work on them.
Old Dec 23, 2003 | 10:21 AM
Ganey's Avatar
Ganey
Since it was working good:
Make sure your primary piston is not stuck down. Engine off, in the float vent tube, you can use a small screwdriver to push piston down a little, should spring back up. If not, you can clean out w/ carb cleaner & hook it w/ a wire & pull it back up.
You may need to richen idle mixture & tune it.
To Q-jet on built engine...bad idea?
