Power Steering Pump Rebuild
Old Dec 23, 2003 | 01:17 AM
Disco_Mike's Avatar
Disco_Mike
Default Power Steering Pump Rebuild
I need to rebuild my power steering pump. I have seen rebuilt kits in different catalogues. How much of a pain is this to do? Would you recomend having someone else rebuild it. It is the original factory pump so I want to keep it.
Old Dec 23, 2003 | 06:24 AM
mapman's Avatar
mapman
Default Re: Power Steering Pump Rebuild (79Fever)
A rebuild kit is about $12 from Autozone. The pumps are pretty simple so take a whack at it. If you mess it up you can always use the old pump as a core. :smash: I would just follow the Unit Repair procedure in your 1979 GM Shop Manual.
[Modified by mapman, 6:03 AM 12/23/2003]
Old Dec 23, 2003 | 10:01 AM
Stewart's74's Avatar
Stewart's74
Default Re: Power Steering Pump Rebuild (mapman)
My rebuild took all of 20 minutes. Very easy. Got the kit from Zip.
Old Dec 23, 2003 | 11:52 AM
Disco_Mike's Avatar
Disco_Mike
Gentlemen,
Thank you for your opinion. I will give it a try. mapman. the gm manual is one of the items I need to purchase yet.
To Power Steering Pump Rebuild
