which intake?
Old Dec 24, 2003 | 12:34 AM
wadey's Avatar
wadey
Default which intake?
Looking to buy an aftermarket intake (alum) for my '76 with holley carb. What is my best bet to fit under stock hood?
thanx wade
Old Dec 24, 2003 | 08:37 AM
redwingvette's Avatar
redwingvette
Default Re: which intake? (wadey)
Edelbrock Performer #3701 is a direct replacement or #2101 (without EGR). It will work with stock spreadbore carb or squarebore carbs.
http://edelbrock.com/automotive/index.html
Old Dec 24, 2003 | 02:59 PM
Jasonty's Avatar
Jasonty
Default Re: which intake? (redwingvette)
I'm more then happy with my Weiand Stealth, but you do have quite a few choices such as the intake mentioned above...
Old Dec 24, 2003 | 04:11 PM
Col-UK's Avatar
Col-UK
I just fitted an Edelbrock performer 2101 with a Holley on top. I had to use a Moroso 14"X3""dropdown" airfilter (2 1/2" stack height) to clear my '80 bonnet (hood, as you boys call it)
Old Dec 24, 2003 | 04:26 PM
Chris69's Avatar
Chris69
I went with the newer Performer EPS (2701). Edelbrock claims it's a better design and adds a few extra ponies. It's only 1/4" taller than the Performer. It's for square bore carbs like the Holley, so you won't need an adapter plate like you would if you wanted to mount a Holley on a Performer 2101 manifold.
:cheers:
Old Dec 24, 2003 | 09:46 PM
Aaron360's Avatar
Aaron360
Cruising
Default Re: which intake? (Chris69)
I was able to run the Edelbrock Performer RPM Air-Gap under my stock 74 hood with a lo-pro air-cleaner.
-Aaron
Old Dec 24, 2003 | 11:11 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: which intake? (Aaron360)
-Aaron
I even have a Victor Jr. plus a 1/2 inch spacer under my stock height hood with my drop base air filter setup (1 1/4 inch drop with 2 1/4 inch filter)
To which intake?
