1975 Door Panel Removal
Old Dec 26, 2003 | 10:26 PM
poncho_1119's Avatar
poncho_1119
Default 1975 Door Panel Removal
Hi -
I'm trying to remove my door panels to be able to take off my exterior door handles and door locks for painting (and for a minor repair on the corner of the door). I got the interior handle off no problem, but is there a trick to removing the panels?
Thanks,
James
:confused:
Old Dec 26, 2003 | 11:21 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: 1975 Door Panel Removal (poncho_1119)
There is a screw in each upper(forward & back) corner, your "S" clip at the front lower corner(maybe one towards the back also), your "lock" handle has a special clip behind it like the window crank. You will not have this window crank of course if you have power windows. Then there are several funky type fasteners that work like big velcro pieces. Little plastic ***** that interlock into a receiving piece without any type adhesive. Usually one side stays with the other when you pull the panel apart form the metal door part.
Old Dec 27, 2003 | 12:17 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Paul nailed it, but there are also some screws on the door pulls.
Old Dec 27, 2003 | 09:37 AM
Paul Borowski
Default Re: 1975 Door Panel Removal (Big Fish)
Darn it, I knew I was forgettin' somethin. The old Alzheimers settin in :yesnod:
Old Dec 27, 2003 | 11:00 AM
poncho_1119
Thanks Paul and Big Fish. I appreciate your help.
James
To 1975 Door Panel Removal
