82 green oxidation on radiator
Old Dec 27, 2003 | 12:14 AM
mannymen's Avatar
mannymen
Default 82 green oxidation on radiator
my 82 radiator has green oxidation on it. someone told me that my radiator is going to give out soon. is this true? what does the green oxidation mean?
Old Dec 27, 2003 | 12:19 AM
GDaina's Avatar
GDaina
Default Re: 82 green oxidation on radiator (mannymen)
yep, time to get a new one...green means it's leaking coolant
Old Dec 27, 2003 | 12:48 AM
Disco_Mike's Avatar
Disco_Mike
Default Re: 82 green oxidation on radiator (GDaina)
:iagree:
open the cap. if you see stalagmites (or is it the stalagtites) time to replace the radiator. I had a similar problem on my 79. had the orginal recored using a core with extra cooling fins per inch. I have had no problems since.
Old Dec 27, 2003 | 12:56 AM
mannymen's Avatar
mannymen
what are stalagmites (or is it the stalagtites)?
Old Dec 27, 2003 | 01:12 AM
MN-Brent's Avatar
MN-Brent
Stalagmites are spike shaped formations as is Stalatites.
The difference is stalagmites are pointing up, say from a cave floor and stalagtites are pointing down, say from a cave ceiling. 8th grade science class.
Or it could be the reverse :D
Brent...
Old Dec 27, 2003 | 02:20 AM
mannymen's Avatar
mannymen
Default Re: 82 green oxidation on radiator (MN-Brent)
Oh! Thanks for the info.
BTW, i failed 8th grade science. had to re-take it in summer school.
Old Dec 27, 2003 | 02:13 PM
Richard Cooper's Avatar
Richard Cooper
Mannymen,
If you have green oxidation then you have a leak someplace near where you are seeing the green. :seeya
Old Dec 27, 2003 | 05:24 PM
Paul L's Avatar
Paul L
Copper oxide is green. Could be normal corrosion. Spray on Simple Green, flush with water and re-paint with a semi-gloss black heat paint.
These roofs are copper.
http://www.parl.gc.ca/Information/Photos/cb-008-e.htm
[Modified by paul67, 5:27 PM 12/27/2003]
Old Dec 27, 2003 | 06:27 PM
GDaina's Avatar
GDaina
Default Re: 82 green oxidation on radiator (paul67)
Paul, aren't Small Block radiators aluminium (As the English would pronounce it)
Old Dec 27, 2003 | 06:42 PM
Paul L's Avatar
Paul L
George,
All 1973-82 Corvettes used a Harrison copper radiator. And I am Canadian, not English ;) .
Old Dec 27, 2003 | 06:53 PM
GDaina's Avatar
GDaina
Thanks, I was thinking they were still aluminum
Old Dec 27, 2003 | 06:54 PM
Skyhigh82's Avatar
Skyhigh82
Just had my core replaced with a copper core at radiator shop $175.00.
Old Dec 27, 2003 | 06:58 PM
Paul L's Avatar
Paul L
I suspect if the poster cleans up the green area and hits it with some paint he will be good for quite some time. My 1979 rad is still fine after 24 years. A pressure test might be advised to get a true reading before next summer comes. He would not wish to get stranded on a freeway!
Old Dec 27, 2003 | 07:01 PM
markdtn's Avatar
markdtn
Default Re: 82 green oxidation on radiator (Skyhigh82)
Probably still ought to replace it. It's 20+ years old now. Unless it has had excellent care it is probably wearing thin and will leak soon. You could clean it and see what it does on the outside, but it is probably clogged and nasty on the inside. You could have it re-cored for that $175 or so or get a nice Aluminum replacement from DeWitts for a bit more. You would have way more heat rejection capacity and they look neat too.
Old Dec 27, 2003 | 07:02 PM
Paul L's Avatar
Paul L
George,
No problem. In my transition from C3 to C2 I have learned a lot!
Old Dec 27, 2003 | 07:49 PM
Paul L's Avatar
Paul L
Default Re: 82 green oxidation on radiator (markdtn)
That is good advice. Despite my comment re the 24-year-old rad still doing well I would have it recored before next summer. Mr. DeWitt gives you other options if you wish to go up-scale.
Old Dec 27, 2003 | 09:35 PM
GDaina's Avatar
GDaina
Yup...only way to tell and if there are leaks....
To 82 green oxidation on radiator
Old Dec 27, 2003 | 09:44 PM
mannymen's Avatar
mannymen
where can i get it pressure tested? can i do it myself?
Old Dec 27, 2003 | 10:11 PM
GDaina's Avatar
GDaina
You might be able to rent it at autozone, Murrays, or any u rent um. the pressure tester is expensive to buy, or you can drive to a radiator shop and they will pressure test the rad for you
Old Dec 27, 2003 | 10:20 PM
markdtn's Avatar
markdtn
That tool is kind of expensive, but after having one it is hard to do without. You can pump up the pressure with the car cold and find loose radiator hoses, loose t-stat housings, marginal water-pump seals, etc. You would be amazed at how many cars losing water can be attributed to loose radiator or heater hoses-also radiator caps. Of course, it will also pressurize the radiator and that is what you are looking for here. It fits most American cars from mid-80s back and adapters can be bought for later American also Japaneese and German cars with different necks.
