Speackers for my 81
Old Dec 31, 2003 | 09:12 AM
jaybird81's Avatar
jaybird81
Default Speackers for my 81
I am thinking of replacing the stock speackers in my 81. My question is what size speakers fit as replacements with out major modifications? Also how do I remove the front speakers on the top of the dash? any help would be great. thanks!
And Happy New Year :cheers:
Old Dec 31, 2003 | 09:52 AM
LAWTON54's Avatar
LAWTON54
Default Re: Speackers for my 81 (jaybird81)
The grills slides out, they are held in place by to screws. This will take less than ten minutes. Hope this helps.
Old Dec 31, 2003 | 10:28 AM
John 65's Avatar
John 65
6x9 ovals in the rear.
Old Dec 31, 2003 | 10:57 AM
Crash80's Avatar
Crash80
4x6 speakers in the dash. You need a 7mm hex head socket that is as low as you can find. Getting in there under the angle of the widshield is not a hell of a lot of fun. The hex head screw are recessed down in the dash a bit making it even more difficult. I did mine with an extension and a universal on the 7mm socket. I would recommend putting some bass blockers on your front speakers as well. A 4x6 doesn't handle tons of volume with low end going. I ended up putting a little powered sub in the back of mine to help out the 6x9 speakers back there and still had room to store the t-tops. It is not a big "ricer" sub, just something to give the tunes a bit of punch, not license plate rattling.
Old Dec 31, 2003 | 09:52 PM
c3-4me's Avatar
c3-4me
Not sure if your '81 is like my '80, but make sure you get shallow enough 4x6's. I had to return my first set of 4x6's becase they bottomed out too soon :rolleyes:
Here is what I did with the rear...
To Speackers for my 81
