OEM Part Number
Old Dec 31, 2003 | 01:17 PM
TRUE-DUALS's Avatar
TRUE-DUALS
Default OEM Part Number
Can anyone here provide me with a GM part number for wiper blades for a 72. I have tried several and they sit to high and will not allow the cover to sit flat. I also need to know if the pegs on the wiper arms are opposed of one another. I'm not sure if this is a Bubba thing. Thanks :cheers:
Old Dec 31, 2003 | 05:32 PM
TRUE-DUALS's Avatar
TRUE-DUALS
Default Re: OEM Part Number (TRUE-DUALS)
TTT
Old Dec 31, 2003 | 07:41 PM
Pete79L82's Avatar
Pete79L82
I can't help you with a current part number but the on the arms should be opposite each other. When the blades are in the parked position the left blade pin should point up and the right blade pin should point down.
Pete
Old Jan 1, 2004 | 12:53 AM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: OEM Part Number (Pete79L82)
I have an original GM Corvette parts book for the 1953-82 cars. Here is the GM number for the the wipers
1664394 is for the blades
14029850 is for the wiper refills for the blades
I don't know if the numbers are still good or if they have been superseded. A GM dealer can tell you.
Old Jan 1, 2004 | 08:14 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: OEM Part Number (Corvette ED)
I doubt that GM still has correct arms for your car. You might end up looking for good used ones at Corvette parts dealers, swap meets, etc.
I tried several styles on my 69, and had the same closure problem until I got hold of a pair of originals. They're very thin and "low profile". Chuck
Old Jan 1, 2004 | 08:29 AM
TRUE-DUALS's Avatar
TRUE-DUALS
Default Re: OEM Part Number (Chuck Gongloff)
Thanks all for your help
To OEM Part Number
