picking up c5 seats tommorrow
Old Jan 2, 2004 | 12:13 PM
PatsLs1vette's Avatar
PatsLs1vette
Default picking up c5 seats tommorrow
i bought a set of c5 black seats from a forum member this morning,gone to meet tommorrow and get them.Instead of trying to find something to fit,i know these will with alittle work,and i like the idea of them sitting higher so i can see over the hood.
Old Jan 2, 2004 | 12:22 PM
markdtn's Avatar
markdtn
Default Re: picking up c5 seats tommorrow (patsnitrovette)
The fits I have seen look great. Good luck with it. Are you going to try to use the electrics on the drivers seat, or both like a passenger seat?
Old Jan 2, 2004 | 12:23 PM
GeoffSchultz's Avatar
GeoffSchultz
Default Re: picking up c5 seats tommorrow (markdtn)
How hard is it to make them fit?
Once they are in, will a 6'2"-6'3" guys fit as comfortably in there as with the stock C3 seats?
Thanks!
Old Jan 2, 2004 | 12:25 PM
flynhi's Avatar
flynhi
FYI, I'm 6'1" and was unable to make a set of C5 Sport seats fit low enough to avoid my head hitting the softtop crossbrace.
Some have made these seats work by lowering the floorpan but that was more work than I wanted to tackle.
I ended up with a set of 96 collector seats which fit much better.
Old Jan 2, 2004 | 12:34 PM
PatsLs1vette
Default Re: picking up c5 seats tommorrow (flynhi)
id like to use the power but if i cant no big deal,im short to begin with so if they do sit up higher thats fine,plus i have tilt tele wheel for leg room.Ill try and take pictures of install also,i have complete interior out right now anyway.
Old Jan 2, 2004 | 04:08 PM
GeoffSchultz
Thanks flynhi.
So do you think about any C4 seats would fit pretty good in a C3 and a 6'2" guy would not band his head? Or only those from a particular year?
Old Jan 2, 2004 | 04:11 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: picking up c5 seats tommorrow (GeoffSchultz)
Good deal Pat. Make sure to post pics. Keep us posted on the seats and how they look in your car.
[Modified by Eddie 70, 4:12 PM 1/2/2004]
Old Jan 2, 2004 | 04:48 PM
gdh's Avatar
gdh
Default Re: picking up c5 seats tommorrow (Eddie 70)
I'm 6'1" and I have no problem with my C5 seats, just cut off the front curl (drill out the rivets) - yes they do sit a little higher but they are just so comfortable and very easy to get in and out of.
Old Jan 2, 2004 | 05:05 PM
PatsLs1vette
Default Re: picking up c5 seats tommorrow (gdh)
ghd thats good to hear thanks for the info.
Old Jan 2, 2004 | 06:30 PM
reidry's Avatar
reidry
If anyone might be interested. I've still got a set of C5 seats for sale. Asking $725. These things are beautiful, I just seem to be on the wrong end of the country for those interested! Go Figure.
Ryan
Old Jan 2, 2004 | 10:55 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: picking up c5 seats tommorrow (reidry)
Ryan
are they sport seats? are they power?
Old Jan 3, 2004 | 12:27 AM
reidry's Avatar
reidry
Default Re: picking up c5 seats tommorrow (Metal Wulf)
Basic Seats in Black, power drivers, manual passenger. I have an extra manual frame as well. I've got some components for a second power frame.
Seats are beautiful. Here's the link...
http://forums.corvetteforum.com/zerothread?id=714762
Ryan
Old Jan 3, 2004 | 10:16 AM
EDDIEJ82's Avatar
EDDIEJ82
Good luck with your seats Pat, I kow you were really heartbroken when the others didn't fit. Hope everything works out for you this time.
Old Jan 3, 2004 | 12:03 PM
dreamn2's Avatar
dreamn2
Congrats Pat, you will not be disappointed. The electrics should not be a problem as far as clearance. You will definitely enjoy the ride. :cheers:
Old Jan 3, 2004 | 04:34 PM
PatsLs1vette
Default Re: picking up c5 seats tommorrow (dreamn2)
ok i got them and they fit great and look so much better then the old seats,i just stuck them in for now ,dont have the carpets or anything in yet till im done with body work for flares,but ill take a few pics of them sitting in there.So much more comfortable. :party:
Old Jan 3, 2004 | 04:45 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
you better :yesnod:
Old Jan 3, 2004 | 04:52 PM
gdh's Avatar
gdh
after looking at your engine I have decided to do a complete frame off resto (in 2 years) and put all else on hold right now. My frame is near perfect so it is time to protect it with some POR. Will likely drop a Z06 engine and 6 sp in at that time and crate my existing engine. Also put in some a/c as well - might as well do it all at once and have a virtually new vette under my C3 vert. for long distance comfort cruising.
To picking up c5 seats tommorrow
Old Jan 3, 2004 | 06:33 PM
Corz's Avatar
Corz
If you are going to drop an LS6 in there.. put a ZF6 speed out of a late Fbody.
that way you wont have to destroy your frame trying to get a rear mounted transmission in there
Old Jan 3, 2004 | 07:14 PM
PatsLs1vette
Default Re: picking up c5 seats tommorrow (Corz)
Dont look at all the sanding dust inside,it will be cleaned. :yesnod:
Now i got them for $325.00,drivers side has small tear in side bolster,3 inchs long,going to have repaired.For the price i couldnt resist.
Old Jan 3, 2004 | 07:19 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
That's nice Pat. :thumbs: Beautiful!
Ed T can tell you how to patch that tear up. He does nice work. :D
Do you sit much higher than stock? I can't go much higher than stock. :sad:
