Is my head gasket leaking??
Old Jan 2, 2004 | 01:12 PM
killervette666's Avatar
killervette666
Default Is my head gasket leaking??
On the pasenger side of the engine there seems to be some oil leaking down from what appears to be the head gasket or the valve covers...how do i check to see which one it is?
Old Jan 2, 2004 | 01:17 PM
GDaina's Avatar
GDaina
Default Re: Is my head gasket leaking?? (killervette666)
Head gaskets don't leak oil....if your head gasket is blown, you will have water in your oil, and a loss of power....change your valve cover gaskets. If they leak oil, they are brittle
