Damn locksmiths!
Old Nov 12, 2011 | 12:26 AM
myoriginal77's Avatar
myoriginal77
Should have been here in 2004 when the thread was fresh ....
Old Nov 13, 2011 | 11:34 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Not to mention hes not a vendor on this site and he is advertising his co...
well not for long...LOL
Old Nov 14, 2011 | 05:12 PM
alexroyle's Avatar
alexroyle
7th Gear
Originally Posted by ;1546075762
Cali my GM Parts man has a kit that he can make anything match with. However it does require lock removal from the door.
He just basicly sticks in your existing key and drops in the little brass tumblers to match each key. So you can have your locks matched to your ignition key as originally intended.
I recently had my El Camino door locks replaced with new ones and he keyed them to match another vehicle I own to eliminate my carrying an extra door key around. Jim
Had no keys on my 68, and its hard as hell to get 68 cylinders in the US let alone in the UK!! My answer was to use the keys and tumblers from a new set of mid 70's vette cylinders and install these in the original 68 cylinders. Its a little tricky as you have to carefully remove the 6 tumblers from the new locks whilst keeping the order correct, but it all fits ok into the originals. Make sure you have your eyes peeled and a clear bench or all hell will brake loose - Beware the tumblers are spring loaded!!!! Worked for me. Keys were slightly tight to start off with but now work perfectly.
Old Nov 14, 2011 | 11:31 PM
78,00,69JRM's Avatar
78,00,69JRM
Default 69 Corvette Door Keys
The modern square key blanks do not work in the 69 Vette door lock. The original key has the side slot that is about 1/8 inch longer than the new key blanks for 69. The locksmith here in Santa Maria CA discovered why the key would not work after I removed the lock assembly. You either have to find an original key blank with the long slot or cut the slot further back in the key blank. After he lengthened the slot the key would open the door. Some type of safety device used on the Corvette lock assembly.
Old Dec 12, 2011 | 02:43 AM
rehana1406's Avatar
rehana1406
1st Gear
Locksmith provides security and locksmith assistance for each and every requirement, among them lock accessories and keys of all different kinds. Give us a call regarding the safety and security of you and your family. Also, whenever you secure yourself out of your motor vehicle or home, we are able to support you no matter the period of the day or nighttime.
Locksmith companies in Dan Diego area
Old Dec 12, 2011 | 08:41 AM
fanmanbd's Avatar
fanmanbd
I had this problem on my 73. Had to find an original B&S key blank.
Old Feb 13, 2022 | 03:22 PM
ghoastrider1's Avatar
ghoastrider1
Maybe this will help someone somewear . Its very, very old school. When I was 16 ( I am 72 ) I drove a 48 Plymouth to HS. I started having problems that the ignition key would not turn to on. My Grandparents happened to be visting my parents. (1966). Granpa just happened to be a mechanic at a Dodge dealership in past times. He came up with a can of lighter fluid. He squirted some in the keyhole and the key
(after key was removed ) ran the key in and out about 10 times, never another problem. I KNOW, that wasnt a corvette but hope this passing of old info will help someone sometime. Keep up the wave.
Old Feb 13, 2022 | 03:24 PM
ghoastrider1
Maybe this will help someone somewear . Its very, very old school. When I was 16 ( I am 72 ) I drove a 48 Plymouth to HS. I started having problems that the ignition key would not turn to on. My Grandparents happened to be visting my parents. (1966). Granpa just happened to be a mechanic at a Dodge dealership in past times. He came up with a can of lighter fluid. He squirted some in the keyhole (after key was removed ) ran the key in and out about 10 times, never another problem. I KNOW, that wasnt a corvette but hope this passing of old info will help someone sometime. Keep up the wave.
Old Feb 14, 2022 | 09:06 AM
BKbroiler's Avatar
BKbroiler
Strange
