Missing 82 Emission Control Info Label, need Info?
I want set timming and dial in my 1982 Crossfire after some work.
The Engine Compartment Emission Control Information Label is missing.
The Factory Shop Manual as well as other Repair Manuals refer to the Label for specifications.
I need need timming, idle spec.'s ect.?
Can I get a copy of the Label or the listed info?
Re: Missing 82 Emission Control Info Label, need Info? (PARKS)
Welcome to the Forum.
GM has many of these (and other) decals available. If you just want to get the car running properly you might want to check some of the articles at the FAQ site below.
Re: Missing 82 Emission Control Info Label, need Info? (Skyhigh82)
Remember to disconnect the single wire connector that will by-pass the electronic spark control unit before you check/change timing.It is near the tachometer filter connector on drivers side between distributor and firewall.
