Putting in the trailing arms
Old Jan 6, 2004 | 09:41 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
Default Putting in the trailing arms
Finally getting time to put the rebuilt trailing arms back in today. Got them back from rebuild about a month ago. Christmas and vacation took priority. Wish me luck. :smash: :smash: :smash: :smash:
Old Jan 6, 2004 | 10:11 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Default Re: Putting in the trailing arms (brooksman9)
Good luck ! Hope your project goes smooth !
Old Jan 6, 2004 | 10:15 AM
norvalwilhelm's Avatar
norvalwilhelm
The only problem you should run into is putting the through bolt in. I grease it weel then use a pair of pliers. Feed it into the back side hole first, install the trailing arm keeping it pushed to the outside while grasping the bolt with the pliers.
While I have done this a dozen times it only takes a little luck and about a minute of actually fiddling to get it through.
Add the shims last, I prefer stainless shims and they must be slotted type,
Good luck
Old Jan 6, 2004 | 10:24 AM
brooksman9's Avatar
brooksman9
Default Re: Putting in the trailing arms (norvalwilhelm)
Used fishing line method from 69myway for first one. Worked good. :hurray: :hurray:
Old Jan 6, 2004 | 09:33 PM
bigvette1's Avatar
bigvette1
One suggestion
Put a 9/16" or so socket under the end of the t-aim where it goes into the mounting area and a floor jack or bottle jack under the rotor. Now holding it in postion is only to help balance while you fish the bolt through.
Old Jan 9, 2004 | 08:50 AM
brooksman9's Avatar
brooksman9
Default Re: Putting in the trailing arms (bigvette1)
Both arms installed. almost have everything back together.Damn parking brake cable was the hardest part. Should have ordered caliper piston retaining holder to replace brake pads. Now work is interferring with vette time. All I know about vettes I learned from this forum. Thanks to all :party:
Old Jan 9, 2004 | 08:58 AM
groovyjay's Avatar
groovyjay
Good to hear it turned out ok. I did mine two years ago and it was a real PITA! :cheers:
Old Jan 9, 2004 | 09:46 PM
petty44's Avatar
petty44
I'm feeling your pain :smash: :cheers: bushog
To Putting in the trailing arms
