Engine pain, dressing
Old Jan 6, 2004 | 11:26 PM
wilcox's Avatar
wilcox
Default Engine painT, dressing
Is it possibe to paint the engie without removing it??? maybe take out parts around the engine. If so, what kind of pain/dressing do u guys use? Also... Does anyone offer preformance packages that have heads and cam and intake? Sorry for the lame questions, just getting into this hobby.
WOOPS... PainT not Pain!
[Modified by wilcox, 4:32 AM 1/7/2004]
Old Jan 6, 2004 | 11:58 PM
shawn_cake's Avatar
shawn_cake
Default Re: Engine painT, dressing (wilcox)
Just use a good lambs wool roller and latex paint!!
:D :rofl: :rofl: :rofl: :thumbs:
Sorry - couldn't resist the joke...
Old Jan 7, 2004 | 12:49 AM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
The people who make POR 15 have a nice engine painting kit that includes everything you should need to do the job except the labor! :lol:
Costs $40, but if this stuff is anything like their POR 15 product, you will never have to do it again as it will last forever! :yesnod:
Check them out at:
http://www.por15.com
:seeya
[Modified by ACECO, 12:50 AM 1/7/2004]
Old Jan 7, 2004 | 08:49 PM
joe73vette's Avatar
joe73vette
Default Re: Engine painT, dressing (ACECO)
I detailed the engine compt in my old '70 Firebird with the motor still in. It was an easy weekend project.
First degrease it as well as you can using gunk foaming cleaner and pressure sprayer at a carwash. Then drive it home and start by removing the fan, pulleys, and the accessories and their brackets. Also remove the distributor, carburetor and fuel line if you want, or mask them off. Then re-wash everything under the hood with hot water and tide laundry detergent. Wire brush all the rust off and wipe everything down with laquer thinner. If you have chrome or cast valve covers remove them and mask along the edges or put junk ones on.
Now mask the fenders windshield and crossmember. Paint the motor orange, trying not to get too much overspray on the exhaust or inner fenders. Let the paint dry overnight. While you are waiting, clean and paint the pulleys and accessory brackets semi-gloss black Also paint the air filter housing the same color.
Next day, wrap the motor in big plastic bags to protect it from overspray. Mask off anything else you want to keep natural color, like the radiator shroud. Now paint everything under the hood with semi-flat black (underhood black or rubber bumper black).
When the paint dries, put everything back together and take pictures :-)
Joe
Old Jan 7, 2004 | 11:50 PM
comp's Avatar
comp
Default Re: Engine painT, dressing (joe73vette)
he's got it about covered, i have taken ex. off to get it better also used brushes in tight areas you can still see, take your time it's worth it.
Old Jan 8, 2004 | 09:53 AM
flood's Avatar
flood
Default Re: Engine painT, dressing (comp)
I have seen some of that ex manifold paint but my dad said it starts to look like crap after a little while. Has anyone had any experience with this stuff or another product to recommend? :cheers:
Old Jan 8, 2004 | 01:57 PM
Corvette JABO's Avatar
Corvette JABO
Go to http://www.jegs.com, they have tested packages on intake and head upgrades. Its easier to order a catalog and thumb through it page by page. Jabo
Old Jan 8, 2004 | 05:32 PM
GATOR454's Avatar
GATOR454
Yes, it is possible to paint the engine witout removing it. Even a big block.
I agree with joe73vette. Preparation is the biggest part of the job.
Old Jan 8, 2004 | 05:37 PM
JJMURFS's Avatar
JJMURFS
Default Re: Engine painT, dressing (GATOR454)
:iagree:
But at some point it is just easier to remove the engine put it on a stand and paint it.
Old Jan 8, 2004 | 05:51 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Just did mine...take a lot off..lots of tape and cardboard...lot's of time...Not perfect, but...
before...
After...
[Modified by Avette4me, 4:52 PM 1/8/2004]
Old Jan 9, 2004 | 12:05 PM
shawn_cake's Avatar
shawn_cake
Default Re: Engine painT, dressing (Avette4me)
Super blue paint job!!
WOW!
Old Jan 9, 2004 | 08:59 PM
DaddyO's Avatar
DaddyO
Default Re: Engine painT, dressing (flood)
I used the POR-15 engine paint and highly recommend it!
:thumbs: :thumbs: :thumbs:
Old Jan 9, 2004 | 09:49 PM
78calvette's Avatar
78calvette
Default Re: Engine painT, dressing (DaddyO)
Use aluminum foil instead of paper and tape on the smaller areas.
Mark
Old Jan 9, 2004 | 10:10 PM
Ganey's Avatar
Ganey
Yes, but you need to do a topic on that which includes your setup, trans., etc. & your intended use, what you want, etc.
Otherwise expect Pain. Sort of like if a shoe shop only had 1-3 sizes for all.
To Engine pain, dressing
