AC question
Old Jan 7, 2004 | 03:23 PM
Koz
Guest
Posts: n/a
Default AC question
Can the AC be tested or will it work when the outside temp is.. lets say.. 20 degrees? Or will the compressor just not turn on.. Thanks
Old Jan 7, 2004 | 03:44 PM
lbell101's Avatar
lbell101
Default Re: AC question (Koz)
I'm not that familiar with the 80 model. But the AC should turn on if the system isn't controlled by a thermostat. Certainly early ones should turn on, my 69 would. I know on some newer cars the AC is used in the winter when the defrost first comes on (along with heat). This dehumidifies the air so any condesation won't end up on the windshield and fog it up.
Old Jan 7, 2004 | 03:51 PM
Fevre's Avatar
Fevre
Default Re: AC question (lbell101)
I had a 79 olds that stated in the owners manual the a/c comp would kick on when the temp was over 32^, not sure how it was able to meter the air temp but that is what it said. Before I know that I used to turn on the def to keep cool thinking I was saving gas by not using the a/c. :lol:
To AC question
