Power Valve
Old Jan 7, 2004 | 10:24 PM
duliz's Avatar
duliz
Default Power Valve
I recently changed carburetors, from an 850 holley VS to a Double pumper Barry Grant. I checked the power valve that came with the holley and the opening vacuum is 4.5Hg. This power valve seems way too small for an engine with a fairly mild hydraulic roller cam (duration 224 234 @ .050) It seems to me that an 8.5Hg is more adequate. My question is how can I make sure I'm using the correct power valve? :banghead:
Old Jan 7, 2004 | 10:53 PM
yogi78's Avatar
yogi78
Default Re: Power Valve (duliz)
If you do not have a high overlap cam then you should choose a power valve that opens 2 in (hg) below your normal steady cruising speed vacuum reading. If radical cammed then you should select one that opens 2 in (hg) below the manifold vacuum at idle, ( in gear if an automatic). Hope this helps.
Old Jan 7, 2004 | 10:56 PM
78 Vette's Avatar
78 Vette
Default Re: Power Valve (yogi78)
:iagree:
That is buy the book 100% :thumbs:
Old Jan 8, 2004 | 11:41 AM
norvalwilhelm's Avatar
norvalwilhelm
I agree with the other 2 guys. You want your power valve to open when passing or even going up a hill. If you can install even a temporary vacuum gage and get a power valve just a few points less then the running at a steady cruise speed for your combination. If you step even moderately heavier like going up a hill the vacuum should fall below the power vavle you choose.
Old Jan 8, 2004 | 11:59 AM
BigBadRed's Avatar
BigBadRed
On my street avenger (wild cam, but don't know what it is) holley tech support had me go half my idle vacum. Ended up with a 4.5 power valve.
To Power Valve
