Dot 5 ?
Old Jan 8, 2004 | 08:46 AM
Schwee's Avatar
Schwee
Default Dot 5 ?
My new VBP Calipers arrived yesterday. New pads and rotors, too.
Should I upgrade to Dot 5 brake fluid or is it just a waste of money?
My 81 is a daily driver and not a hot rod.
Dave
Old Jan 8, 2004 | 09:43 AM
mapman's Avatar
mapman
Default Re: Dot 5 ? (Schwee)
To use Dot 5 you need to completely flush the old system as the DOT 5 silicone is not compatible with the DOT3/4 glycol based fluid. Dot 3/4 is hydroscopic and will absorb water, while DOT 5 is not. Dot 5 has a higher boiling point.
I use Ford HD DOT 3 brake fluid. If you get water in the system, the DOT3/4 will absorb it, then the water will be flushed out when you change brake fluid (we all change our brake fluid don't we :lol: ). With DOT 5 there is a possibility that the water contamination will be trapped and not be flushed out with fluid changes.
If you are going to use the car, I think Ford HD DOT 3 is the way to go.
Scooter70's Avatar
Scooter70
Personally, I use the Valvoline Synthetic that's available at your local Auto Zone. I've used it on the street and for open track days and haven't had any problems. Even the heavy road race guys tend to not use the super-expensive stuff. Castrol LMA or the Ford HD are both highly recommended as well. The best thing to do for your brakes is to flush them every so often and bleed them inbetween flushings. With a daily driver that really doesn't get pushed too hard, you shouldn't really have to worry. Brake fluid likes to absorb water and that's what lowers the boiling point and can cause them to not work as intended. Flushing with new fluid helps to keep the BP up, but on the street, you should never really have to worry. If you want to do more reading on brake fluid theory, check out the Roadracing/Autocross forum.
Wow, that was a long winded response to an easy question. Bottom line: Dot 5 = overkill. Use the cheap (but decent) stuff and keep up with the maintenance.
Old Jan 8, 2004 | 09:47 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Dot 5 does not absorb water like Dot 3 and 4, but it is also alot more expensive. Down here in Louisiana I like to use Dot 5 since we have so much moisture around.
Old Jan 8, 2004 | 04:14 PM
Tom454's Avatar
Tom454
Default Re: Dot 5 ? (Sigforty)
I installed DOT 5 in my C2 and didn't open it up for over 20 years. When I did, the fluid was just as clear & clean as the day I put it in. So I re-used it. Absolutely no problems with the stuff. I am converting all of my cars (all non-abs) one at a time to DOT 5. Makes life so much easier.
The rubber parts wear out and need to be changed way before the fluid gets funky.... if it even does.
Boiling point?? I think that most sports car owners will never push their cars to the point where boiling point has any bearing on the situation. Personally, I think that boiling point is moot: deprived of practical significance : made abstract or purely academic
Lot of 001's wannabe 007's.
Just my experience with the stuff.
An important point was made above.... if you do not get all the water out on your initial DOT 5 bleed, then it will sit, and rust will form in that spot. So.... bleed 'em right the first time.
Old Jan 8, 2004 | 04:20 PM
comp's Avatar
comp
Default Re: Dot 5 ? (Tom454)
i use the Valvoline also, the DOT 4 doesn't seam to absorb as much H2O as
the 3, my 2cents
Old Jan 9, 2004 | 04:18 PM
Dwaynes69BB's Avatar
Dwaynes69BB
From: I can explain it to you, but I can't comprehend it for ya.
I've been running in my '69 for 6 years now with no problems
Dwayne
[Modified by Dwaynes69BB, 4:19 PM 1/9/2004]
Old Jan 9, 2004 | 04:36 PM
mvftw's Avatar
mvftw
Default Re: Dot 5 ? (Dwaynes69BB)
Does anybody use a power bleeder? http://www.motiveproducts.com/ordernow_bleeders.htm
Old Jan 9, 2004 | 04:45 PM
groovyjay's Avatar
groovyjay
I'm using DOT 5 on my 79, no problems what so ever. :cheers:
Old Jan 9, 2004 | 05:23 PM
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Default Re: Dot 5 ? (groovyjay)
:iagree: Been in my 77 for years!!! No problem!!
To Dot 5 ?
