I think it was olivier (GSC3) that posted the link, if not he'll probably know where it is since I think I remember he posted it on the German CorvetteForum.
BTW they say it does 3.7 secs from 0-100Km/h (62Mph) on their website and 3.5 secs on the Ebay. Top speed on their site is 320Kmh and 330Kmh on Ebay. On Ebay the car is claimed to have 600Hp and on their site it says 550Hp... :skep: :skep: :skep:
Technical improvements Wilwood running brake assembly Special chassis of the company Kubetschek - Chassis was completely revised and partly with self-constructions improves, so that the achievement also mobile and up the road becomes convertible. In particular the rear axle range became substantial constructionally changes
Independent cooling systems for engine, Transmission and differential Entire electrical connection conceives again - simple patch cords, centralization the safety devices and relays at one easily accessible place. Satellite detection system in series - perfect theft safety device with all Kubetschek Corvettes.
Complete leather interior equipment Complete adapted high-grade steel exhaust system All hoses and adapters from the aviation technology. Full restoration of all basic metal parts and refinement with most modern techniques Each technical change is tueveingetragen, with the proof of production - Manfred Kubetschek Nuernberg.
Jay, some of your translation is not quite correct,
It says:
Technical improvements:
Wilwood Racing Brake system
Specially crafted suspension system, by kubecheck. Suspension completely overhauled and partially improved with in house developed constructions, this so the new level of performance is quite driveable and streetable. Especially the rear axle has been thoroughly altered.
Independent cooling for engine, tranny & diff
Complete electronics redone, based on new concept of simple plug connectors and centralisation of fuses & relays in an easy to access location
Then indeed the sattelite tracking security system blah blah
Compelte restauration of all load carrying metal structured (i.e. frame and such) and corrosion protection/galvanisation based on modern techniques (just galvanizing)
All technical alterations have been TUB approved and documented with manufacturer data (technical drawings, info.. stuff required by German TUV, something like DOT)
