Interior dye, have you
Old Jan 9, 2004 | 07:03 AM
Toy4Two's Avatar
Toy4Two
Default Interior dye, have you
My door panels and my dash have faded a little over time, and I was wondering if these interior dyes work. No experiance with the stuff.
Thanks :seeya
Old Jan 9, 2004 | 07:43 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Default Re: Interior dye, have you (Toy4Two)
Worked allright for me :thumbs:
Old Jan 9, 2004 | 07:58 AM
vettfixr's Avatar
vettfixr
The dyes work very well if you prepare the surface correctly. You have to clean the vinyl or leather very carefully. I usually use a spray cleaner first like 409. Then follow that up with a rag dampned with lacquer thinner. Don't soak the rag just make it damp. Go over the surface a few times to make sure that all the old wax, silicone, and dirt are cleaned. Once you have the panels clean spray each piece with multiple light coats until you get the coverage you want. Don't try to cover everything in one or two coats because it won't look right. You want light coats so you don't get runs or sags in the paint. Also, don't spray under humid conditions or you'll get blushing in the paint (dye). Other than these tips the dye does a great job. Good luck.
Old Jan 9, 2004 | 07:52 PM
DR76's Avatar
DR76
Default Re: Interior dye, have you (vettfixr)
:iagree: with all the above...
I've also been using "Fusion" paint by Krylon (really!) It's got a "special bond" with plastics and has been coming out surprisingly well. Even though priming isn't necessary (per instructions on can) I've been giving the actual plastic pieces a light coat of etching primer just to be safe, but the center console and the few other vinyl pieces I've done so far have been coming out great w/ the light thinner wipe, as mentioned above.
They have about a dozen or so colors out now and at less than $5 a can...worth a try :yesnod:
That's it for now...
Dr.
Old Jan 9, 2004 | 08:56 PM
JJMURFS's Avatar
JJMURFS
:iagree: If you are just freshening up your interior and not doing a color change, it should work great!!!
Old Jan 10, 2004 | 07:48 AM
ductape's Avatar
ductape
Cruise-In V Veteran
The dyes work very well if you prepare the surface correctly. You have to clean the vinyl or leather very carefully.......make sure that all the old wax, silicone, and dirt are cleaned.......
:iagree:
Vetttfixr is right!! Your local paint shop ie: NAPA store, has stuff to remove dirt, silicone etc. They also have a primer you wipe on. I know it sounds like trouble, but it's worth it! I "freshened" up my whole interior. I also put insulation (air duct with foil on one side) from home depot down under the carpet. I cleaned the interior and bought some dye from a local paint shop. They have the codes to mix it for your car just like paint. If I knew how to put a picture on here to show you, I would. The dye was $60 for a quart. Did all with some left over for "touch ups". You can by a generic color from NAPA or get the stuff from Corvette America, spray can or quart. :thumbs:
To Interior dye, have you
