tranny temp guage in clock spot?
Old Jan 10, 2004 | 10:46 PM
Quinn_Seipp's Avatar
Quinn_Seipp
Default tranny temp guage in clock spot?
Who has one? I am redoing my center console and would like to replace my clock with a temp guage that looks like the rest of the guages. Also how did you go about installing one? :chevy
Old Jan 11, 2004 | 08:41 AM
Paul L's Avatar
Paul L
Default Re: tranny temp guage in clock spot? (Quinn_Seipp)
Beginning in 1981 some optional radios (electronic tuned receivers) contained a digital clock. The clock in the bezel was thus replaced with an oil temp gage as shown in the pic. That was for the engine but I am sure someone has adapted a sensor for transmission heat pickup to drive that gage.
Old Jan 11, 2004 | 09:46 AM
Ganey's Avatar
Ganey
Added the 81 engine oil temp. gauge a long time ago. It will go right in place of clock. Replaced panel w/ 81 panel so all would be same since clock cutout was round. Have done many posts on it.
Paul67 did some topics when he had the 79 & was considering it.
Old Jan 11, 2004 | 09:49 AM
Paul L's Avatar
Paul L
Default Re: tranny temp guage in clock spot? (Ganey)
I never got around to it before I sold the 1979. I sold the parts on EBay.
What I do not know is if the temp range for transmission fluid would fall within the same range as engine oil. If not that gage would be of little use.
[Modified by paul67, 9:56 AM 1/11/2004]
Old Jan 11, 2004 | 10:17 AM
flynhi's Avatar
flynhi
Contact Roger at Corvetteclocks by Roger for this mod.
Old Jan 11, 2004 | 03:57 PM
Paul L's Avatar
Paul L
Default Re: tranny temp guage in clock spot? (paul67)
I had three of those gages at one point. I have one left. E-mail me if you are interested.
Old Jan 11, 2004 | 11:09 PM
Quinn_Seipp
Thanks for the pointers, I was kinda of looking for an aftermarket guage that I could just throw in for now with a bit of custom work that looks and glows similiar to the originals, and hook up once I put my 700r4 tranny in.
Old Jan 11, 2004 | 11:45 PM
markdtn's Avatar
markdtn
I have one of these in a 69. I had Clocks by Roger rebuild it and put an orange needle. Looks like it belongs there. I don't think aftermarket will look right. My next choice would be a tranny temp gauge from a 1 1/2 ton or bigger GM truck. Same basic cab as the 73-87. Take that gauge and use a clock back. It might be close.
Old Jan 12, 2004 | 12:45 AM
Quinn_Seipp
What did you replace with the 81 panel? The black trim? or the blue thing all the guages are connected to? Thanks alot guys, :yesnod:
Old Jan 12, 2004 | 02:02 AM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
... and you [those that don't know] want the fluid 30 degrees cooler than H2O. Also, since we are on the subject, don't bypass the radiator "cooling" coil. It's there to warm the fluid while at cruise.
Old Jan 12, 2004 | 08:46 AM
Ganey's Avatar
Ganey
Just used the 81 black faceplate panel & 81 gauge only. It will work in the 77 panel, just done so all gauge cutouts were the same.
To tranny temp guage in clock spot?
