Gas Pedal Switch?
Old Jan 11, 2004 | 11:20 PM
micks69's Avatar
micks69
Default Gas Pedal Switch?
There is a switch that is attached to my gas pedal that gets activated at full throttle (almost like a brake light switch) What in the world is this and what does it do?
73 454 4spd.
[Modified by micks69, 11:21 PM 1/11/2004]
Old Jan 11, 2004 | 11:37 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Default Re: Gas Pedal Switch? (micks69)
I had the same question when I got mine!!
It activates the cowl flap on the hood to allow fresh air into the air cleaner!
Pretty slick, when it works!
Post pics of yours!
Paul
73 vert, L82, 4spd
markdtn's Avatar
markdtn
It is a kickdown for a TH400 automatic. Either your car started life as an automatic or has the accelerator pedal from one. Or what he said-on a 73 up it opens the cowl door.
[Modified by markdtn, 10:38 PM 1/11/2004]
Old Jan 12, 2004 | 07:22 AM
micks69's Avatar
micks69
Default Re: Gas Pedal Switch? (markdtn)
I'm pretty sure its always been a 4 spd. But there is a build sheet on the tank still so I guess I'll know when I drop the tank. It seems reasonable though that it's for the flap although my hood does'nt have a flap :)
Hmm wonder if this would be a good NOS switch??
[Modified by micks69, 7:23 AM 1/12/2004]
Old Jan 12, 2004 | 07:57 AM
markdtn's Avatar
markdtn
Removable transmission crossmember=Automatic frame. Fixed crossmember=4 speed frame.
Old Jan 12, 2004 | 09:39 AM
redvetracr's Avatar
redvetracr
I have one of those pedals with the switch I just took out of a `71 BB automatic car I am dismembering I think it`s for the "kickdown".
...redvetracr
Old Jan 12, 2004 | 11:24 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Gas Pedal Switch? (73sbvert)
Post pics of yours!
Paul
73 vert, L82, 4spd
Isn't that due to lack of vacuum to keep it closed, which also happens at WOT.
Old Jan 12, 2004 | 11:48 AM
NHvette's Avatar
NHvette
Default Re: Gas Pedal Switch? (BSeery)
It does both - kickdown for TH400 and opens the cowl for 73-up fresh air intake.
:seeya
Old Jan 12, 2004 | 11:54 AM
Fevre's Avatar
Fevre
The flapper is in the cowl section of the hood under the grill near the windsheild, it may have been removed. Mine was not functioning so I removed it along with the cylinoid, better to fresh air all the time anyways.
To Gas Pedal Switch?
