Suspension geometry models. Roll center etc...
Now that I've started the 3D model thing: http://forums.corvetteforum.com/zerothread?id=725050 I have also started modelling the rear suspension. At the same time modelling the geometry it's easy to check the rear travel and body roll efect to wheel alignment.
Here is rear travel sheet: rear-travel in PDF. This is fairly simple and straight forward. I still have to check the geometry once again to be sure about the dimensions, but this shows that in normal travel C3 suspension is pretty good.
But this was really horrible to find out: rear-roll in PDF. This is simply shocking! Please, suspension gurus check this out and tell me if the RollCenter is located correctly... Is it really so that CoG/weight doesn't have any impact on rollcenter? CoG/weight affects only to how much the body rolls, but in the rollcenter? This is how I figured it out, am I correct or not?
I have also videos on both travel and roll, but I have to somehow change the format first. Now they are in .AVI format and they are about 100MB each. Pretty much for a small ten second movie with not too many moving parts...
Can you please explain what is what in those pictures?
It looks like you drew lines from the control arms, they intersect somewhere outside the pic in the IC, then you connected IC to wheel centerline to ground contact point and this, crossing the vehicles centerline gives roll center
Also, it looks as if you placed the instantaneous center for the front on the inside of the car, where it really is on the outside because of the control arm angles
For now I have two guestions.
1. Does CoG or weight of the vehicle have any effect to roll center?
2. What happens to RC when suspension is tilted and the RC locations for left and right side are not at the same height in center line of the car? As you can see from the pics other side is 77mm and the other one 127mm when roll is 3deg? is the roll center in the cross section of these lines (not at the centerline of the car) or at the middle of these lines (about 102mm above ground)? Hope that you can understand what I'm trying to explain...
Pete
[Modified by Pete79L82, 7:14 AM 1/12/2004]
The race car vehicle dynamics by will & doug milliken is an awesome book but it's about 100$ and it's THICK (almost 1000 pages). I want to buy that book too sometime in the future.
http://photos.yahoo.com/bc/lohkay/lst?.dir=/Corvette
and here's some pics and dimesions I took for the corvettefaq...
http://www.corvettefaq.com/c3/5link/index.html
Now that both sides are installed with the spring (only missing the brake hoses) I'll take some more pics when I get the chance. I should test drive it this summer.
The system uses a special center camber bracket, I have the measurements on that thing somewhere, will have to look. As for the hubs, they use cast aluminium sections over the hubs that connect to all the bars, it's clearly visible in the pics on their site.
Double click to enlarge
I wouldn't be too worried if quality heim ends were used, it's not like the C4 dogbones are exceptionally strong either. They are forged aluminium.
