RPO U15 - Speed Warning Indicator
Old Jan 12, 2004 | 04:24 PM
corvettemaster's Avatar
corvettemaster
Default RPO U15 - Speed Warning Indicator
i noticed that this was an option in 67-69. can someone explain what this option consisted of? was it a light in the dash :confused:
Old Jan 12, 2004 | 04:28 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: RPO U15 - Speed Warning Indicator (corvettemaster)
It is an adjustable needle that caused a quiet buzzing if you exceeded the setting. Kinda like an alarm clock...
Trouble is with loud exhaust, open windows you can't hear it :crazy:
Old Jan 12, 2004 | 04:38 PM
Solid LT1's Avatar
Solid LT1
Default Re: RPO U15 - Speed Warning Indicator (427V8)
The Speed Warning system was used by yours trully as a N2O delay switch in his "street race" 69 Camaro. I wired the soleniod relay feed from the "buzzer" of the Speed Warning system for a delay to allow me to get traction befor the 10,000 RPM N2O system hit (now at 45 years old, I can tell all!)
Old Jan 12, 2004 | 04:39 PM
JJMURFS's Avatar
JJMURFS
It consisted of a unique and different than standard speedometer and a buzzer that was mounted behind the dash
To RPO U15 - Speed Warning Indicator
