Mirrors
Old Jan 17, 2004 | 11:15 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Mirrors
My mirrors on my 81 are manul adjusted ones with the little *****. They do not stay where they are adjusted at all. Everytime I shut the door the mirrors just point off to a random direction. The things are really screwed up and it is starting to drive me crazy!!! :crazy: What can i do to fix them??
Old Jan 19, 2004 | 10:36 PM
PewterMetallic98
Default Re: Mirrors (ElectronBlueC3)
BTT
Old Jan 21, 2004 | 11:03 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I aint no expert...
We just pulled the hardware of my fiends 79 L82 and had to fiddle with the mirror. The lever on the inside of the door is conected to four cables that run all the way to pivots on the outside mirror (thorugh the door). If you push the lever one way then the mirror gets pushed in a direction. In order to check the pivots out you may have to remove the interior panel, unbolt the control lever, unbol the mirror and slide out the cable, If it is sloppy you can buy the whole assembly that goes inside the mirror surround and install is teh reverse. Hopefully you can find a way to adjust the pivots but if the cables are stretched then you will have to replace.
Hope this helps. Take your time and take digital phots as you go so you can remember where everything goes.
[Modified by stingry, 10:04 PM 1/21/2004]
Old Jan 22, 2004 | 12:04 AM
PewterMetallic98
Default Re: Mirrors (stingry)
Great, ill get to that really soon. Thanks for your help. :cheers:
To Mirrors
