Priming engine.
Old Jan 19, 2004 | 07:45 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Priming engine.
When an engine is "primed" to get the oil circulating. Will the oil reach the cam and main bearings?
[Modified by 1970 Stingray, 7:46 AM 1/19/2004]
Old Jan 19, 2004 | 08:46 AM
bence13_33's Avatar
bence13_33
Default Re: Priming engine. (1970 Stingray)
Len:
As long as your distributor is in place, everything gets oiled. Most people will use an old distributor and a hand drill to prime the motor. I always just disconnected the coil wire and cranked the motor over. It's a little harder on the starter this way but it still does the same thing.
Old Jan 19, 2004 | 08:57 AM
Fevre's Avatar
Fevre
It takes a good 5 to 10 minutes to get oil all the way up to the rocker arms using an oil pump primer and 10,000 rpm high speed drill so it would take a lot longer to get whole system primed using the starter. I bought a primer like this to make sure oil got everywhere:
http://store.summitracing.com/partde...57#largerimage
Old Jan 19, 2004 | 09:07 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Priming engine. (Fevre)
Yeah, that's the one I'll be using. :yesnod:
Old Jan 19, 2004 | 12:22 PM
Mr.Gearhead's Avatar
Mr.Gearhead
Default Re: Priming engine. (bence13_33)
Whoaaaa... Bence... Isn't cranking the motor over with the starter to get it primed kind of defeating the purpose of priming? I thought an engine was primed by the oil pump to ensure oil was coating all the internals BEFORE they moved and contacted each other? Okay... I am confused... where are my books... he heee :confused:
Old Jan 19, 2004 | 12:27 PM
comp's Avatar
comp
Default Re: Priming engine. (Mr.Gearhead)
with plugs out carb open(no fuel or ign.) it's not that bad, i also use 2 batts. the primer IS the
best way :thumbs:
Old Jan 19, 2004 | 12:32 PM
Garrett1972's Avatar
Garrett1972
I took an old distributor I had laying around, used a metal lathe to take off the gear, (you could use a bench grinder), cut off the weights, and use a good 1/2 inch drill to spin it. It was cheap, and easy to make.
Old Jan 19, 2004 | 12:36 PM
Twin_Turbo's Avatar
Twin_Turbo
Priming is always good but it takes so long for the oil to reach the rockers because it's pumped up by the lifters in a running engine
To Priming engine.
