Hood cable install - where?
Old Jan 19, 2004 | 03:17 PM
viperjesse's Avatar
viperjesse
Default Hood cable install - where?
I'm installing a new hood release cable in my 76, I see where it goes into the car from the engine compartment but I can't find the hole inside. Does anyone know where the access hole is on the inside of the firewall? The old one was completely out so I have no idea where it fed through.
Old Jan 19, 2004 | 03:42 PM
crf311's Avatar
crf311
Default Re: Hood cable install - where? (viperjesse)
It is way up in the corner under the dash. It is easer to see from the engine compartment. I would look there first, so that you have an idea of where it is , then go under the dash to install. The handle bolts up under the dash also.
