From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Window adjustment, need advice
How would I go about adjusting my pass. side window?
It's to far forward and it wont roll all the way up.
I have about a 2" gap at the rear of the window and door.
There manual windows.
Thanks for any kind of help:)
Terry.
You need to follow the procedure in the Assembly Instruction Manual (AIM) or in the factory service manual. There are 3 independent adjustments that can be made, depending on which dimension requires adjustment.
If you don't have the AIM and factory manual for your year Corvette, this is an excellent reason to buy them :D
You have to take off the door panel. As 69SB says, get the AIM and follow the directions. You have 3...maybe 4 adjustments. UP/DOWN, FORE/AFT, and TILT/ROTATION. You can also adjust the IN/OUT too. It's too difficult to try to 'splain here, like trying to tell someone how to tie a necktie over the telephone. :) Chuck
