Alternator
Old Jan 19, 2004 | 06:33 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Alternator
Could an old alternator that still works be draining my battery while not in use? Something is drainging my battery down and that's one thing someone told me to look into but i wasnt sure if that was true or not. Any help? :confused:
Old Jan 19, 2004 | 06:56 PM
MN-Brent's Avatar
MN-Brent
Default Re: Alternator (ElectronBlueC3)
Ive seen it before. Alternator is working but draws down the battery when not running. Its one of those wouldnt believe it until youve seen it type deals.
I think the regulator can have a failure mode where it is still capable of regulating at 14V but has a current draw problem due to a bad transistor stage in its control circuitry. Regulators can have many transistor PN junctions which perform many different tasks regarding regulation.
Brent...
Old Jan 19, 2004 | 06:59 PM
theoUK's Avatar
theoUK
Yep, I know that's perfectly possible..
Not sure of the exact details of how it happens, or if indeed it's what happening with you, but the battery can definitely be drained by a faulty alternator. One way to check, stick an ammeter in series with one of your battery terminals and the corresponding battery cable, and see what current is being drawn at with the key out. Then disconnect the live cables from the alt and see if this current drain goes away. If so, bingo!
Use a high range on the ammeter at first, to avoid blowing any of its internal fuses!
[Modified by theoUK, 12:01 AM 1/20/2004]
Old Jan 19, 2004 | 07:28 PM
mvftw's Avatar
mvftw
Default Re: Alternator (theoUK)
It happened to me on my '86 Camaro. The alternator was drawing 4amps when off :eek:
Old Jan 19, 2004 | 07:50 PM
PewterMetallic98
Default Re: Alternator (mvftw)
Well I just disconnected it completely. Hopefully I will see some results pretty soon. I don't have an ammeter or anything like that yet. Gotta do it the ole fashioned way. :smash:
To Alternator
