Side Exhaust Muffler questions
Old Jan 20, 2004 | 04:29 PM
EricU's Avatar
EricU
Default Factory Style Side Exhaust Muffler questions
I have ordered a set of factory style side exhaust covers from Paragon for my 69 convertible.
From the information that I have found, it seems that a 3" side pipe is the largest that will fit under these covers (and that is with spacers).
The smallest spiral baffel seems to be for a 3.5" pipe so that is not an option.
Any suggestions/experience on what kind of muffler/insert I could run?
I am going to have a set of Stahl headers built and the engine that I am now having built is a 434 cu. in. small block with a pretty decent size solid roller. I am hoping to make around 525 hp.
Thanks for any help, Eric.
[Modified by EricU, 1:30 PM 1/20/2004]
Old Jan 20, 2004 | 07:02 PM
Solid LT1's Avatar
Solid LT1
Default Re: Factory Style Side Exhaust Muffler questions (EricU)
RPM muffler in Hayward, CA makes Lobak spiral mufflers and I think they might be able to help you. Try giving them a call at (510) 783-3714 or 783-3712 (plus they're down the street from Vic Hubbard's Speed&Marine so you can get all your other parts on the way back to the freeway!) I think I recall getting a set for some Stahl side exhausts there but it was several years ago, Good Luck!
Old Jan 20, 2004 | 07:37 PM
Rockn-Roll's Avatar
Rockn-Roll
What's wrong with the '69 stock chambered side exhaust pipes? They are oval shaped so they fit in the space nicely. I think I saw them in Eckler's. Heck, if you are springing the $1500 or so for the factory chrome side exhaust covers then why not spend the $300 for the factory chambered side exhaust pipes? Mine sound awesome!
Old Jan 20, 2004 | 07:39 PM
EDDIEJ82's Avatar
EDDIEJ82
JCL makes custom order spirals. drop Jim a line I'm sure he can help you out
Old Jan 20, 2004 | 09:30 PM
JCL's Avatar
JCL
Eric. Actually given time and money, and more of the latter, you can probably get just about anything under 69 repro covers. I do have a 3.0" baffle, but for your "big" small block I'd suggest at least 3.5".......... :yesnod: :yesnod:
Old Jan 20, 2004 | 10:16 PM
LFZ's Avatar
LFZ
Default Re: Factory Style Side Exhaust Muffler questions (Rockn-Roll)
side exhaust covers are $2300 and mufflers are $430 for aluminized and $770 for stainless. thats some money in side exhaust, but well worth it! :thumbs:
To Side Exhaust Muffler questions
