Possible way to increase caster without shims.
Old Jan 22, 2004 | 08:02 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Possible way to increase caster without shims.
I was doing an alignment on my new front suspension tonight and found my caster was about 9 degrees positive. A stock cross shaft gives about 3 maximum and 5 once I have modified it but now with the same crosshaft I had a range of 7 to 9.
I could not figure out why the change so I pulled the A arm back out just to look. I got the idea that maybe the crosshaft may not have the holes equally spaced between the bushings. A quick look confirmed this and the vernier proved it.
I pulled the shaft out, and the bushings do not need to be pulled to rotate the cross shaft end for end. It only takes a few minutes. I put it back together and I had my 5 degrees back.
What this was telling me is that if I had rotated the shaft last summer I could of got an extra 2 degrees positive caster out of the A arm without any other modification.
So guys if this holds true for you reversing the crosshafts end for end would increase your caster 2 degrees without any other modification.
I don't know if this is the case for everyone but it is something I discovered on my car this even.
Have a good evening
[Modified by norvalwilhelm, 7:03 PM 1/22/2004]
Old Jan 22, 2004 | 09:57 PM
American Boy's Avatar
American Boy
Default Re: Possible way to increase caster without shims. (norvalwilhelm)
That would be awesome. I was prepare to spend a lot of $$ to get the caster around 5 degrees with tubular a-arm. Too bad my car is away for the winter, I'll check it for sure this spring.
Stephan
Old Jan 22, 2004 | 10:27 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Very interesting, indeed. I'll have to take a look at mine. Thanks for the observation.
Old Jan 22, 2004 | 10:32 PM
ZD75blue's Avatar
ZD75blue
Default Re: Possible way to increase caster without shims. (burners)
I wonder about how hard it would be to tweak the spindle angle like when you drop a ford axle... just enough to align the front to racing specs!
:cheers:
Old Jan 23, 2004 | 10:22 AM
NHvette's Avatar
NHvette
Oh no ... I gotta check mine, now. When I pressed the bushings into the top control arm, the shaft looked symmetric. I didn't get the calipers out.
I guess I should hope that I put them in 'wrong'. :lol:
Old Jan 23, 2004 | 10:29 AM
FeedVaal's Avatar
FeedVaal
Default Re: Possible way to increase caster without shims. (NHvette)
For we the suspensionally challenged, what benefits might accrue by increasing caster to this extent?
To Possible way to increase caster without shims.
