Need help identifying LT-1 engine
In short these are my questions:
1. Is there a website with all the block, head, intake, carb identicication numbers that I could use to determine what I have.
2. Where on the block should I look for these numbers?
3. What value would you give this motor assuming its a 1970 LT-1 with the proper heads and intake? It does run just fine but I dont know any details of it other than its ran like a champ the last 2 years for me.
Thanks for any help!
[Modified by sirlockness, 1:25 AM 1/23/2004]
[Modified by sirlockness, 1:26 AM 1/23/2004]
2 - you're looking at the right spot for the stamp pad info. You need to clean the pad surface off a bit better so you can see what characters are stamped up there. Wipe it off and take some omore pics and post 'em. http://www.idavette.net/facts/70.htm has the stamp codes for a '70 LT-1. The 3 letter suffix should be either CTK CTR CTU or CTV.
3 - hard to give a value, since it's really only "original" to one specific car if it really is an LT-1 motor. Maybe someone else would have an idea of value....
Shannon
