Tranny hose leak
Old Jan 23, 2004 | 01:55 PM
Freepop's Avatar
Freepop
Default Tranny hose leak
Guys, for the life of me, I can't get thte hoses to quit leaking on the tranny lines that go to the cooler. The rubber ones that clamp onto the hard line. It does probably make a good corrosion deterent though.
Any suggestions.
Old Jan 23, 2004 | 02:15 PM
NHvette's Avatar
NHvette
Default Re: Tranny hose leak (Freepop)
Make sure it's not just cheap rubber hose.
You want a hose that stands up to the tranny fluid.
Some rubber will expand greatly from the fluid ... then they will never seal right.
:seeya
Old Jan 23, 2004 | 02:22 PM
Freepop's Avatar
Freepop
Default Re: Tranny hose leak (NHvette)
Working with elastomers all the time, duuhhh, that never crossed my mind. I was using gas line, but it doesn't mean that it is compatable with ATF. Will investigate, thanks.
Old Jan 23, 2004 | 02:45 PM
SharkintheWoods's Avatar
SharkintheWoods
Could be the heat. Not the compatability. I know i used fuel line one time and it got rather hard and brittle.
Old Jan 23, 2004 | 02:51 PM
Lit-Bern's Avatar
Lit-Bern
Default Re: Tranny hose leak (SharkintheWoods)
I used a Hydraulic hose line 3/16 id . No leaks yet
Old Jan 23, 2004 | 03:44 PM
Oldguard 7's Avatar
Oldguard 7
I experienced this problem two weeks ago. I used rubber fuel hose and It leaked near the clamp and the fitting into the cooler section of the radiator. I replaced it with transmission cooler hoses I bought from a tranny cooler kit at Advanced Auto Parts. Hasn't leaked again.
Old Jan 23, 2004 | 04:09 PM
Edzred72's Avatar
Edzred72
Default Re: Tranny hose leak (Lit-Bern)
:iagree: :yesnod: :iagree: :yesnod: :iagree: :yesnod: :iagree: :yesnod:
This is the way to go. High temp & high pressure compatable.
Eddie
Old Jan 23, 2004 | 04:53 PM
marshrat99's Avatar
marshrat99
Default Re: Tranny hose leak (Silvr77)
:iagree: Don't ask me why, but don't try using anything other than high-temp, high-pressure on your steering either !!!
Old Jan 23, 2004 | 04:59 PM
Freepop's Avatar
Freepop
Default Re: Tranny hose leak (marshrat99)
Last winter I replaced and I noticed it was hard, but I thought it was the the cold. Boy, do I feel like an idiot after working with elatomers and having compatibility problems, I never thought of it. It doesn't leak bad, but is unsightly.
To Tranny hose leak
