Install question on headers- help.
Old Jan 23, 2004 | 05:39 PM
Imothph's Avatar
Imothph
Default Install question on headers- help.
The search function seems out....so figured I'd just ask.
I picked up a set of Dynomax cerama-coat headers for a 78 Corvette. Im not at home so I cant peer under the hood, so...do I need to get any special brackets for the AC or anything? I know some header applications need extra brackest for the various pullies etc that used to bolt to the stock manifolds.
If so, does anyone have the part numbers?
Thanks,
Old Jan 23, 2004 | 06:03 PM
Wrencher's Avatar
Wrencher
Default Re: Install question on headers- help. (Imothph)
I'd guess you do. I've never been able to just bolt up a set to a late-model engine without some tweaking, even if they come with all the spacers and stuff you need. If your trying to do it in one sitting, then definitely get the dope on required stuff first. I'm betting there are some spacers required.
Hans
Old Jan 23, 2004 | 06:46 PM
Bobchad's Avatar
Bobchad
Default Re: Install question on headers- help. (Wrencher)
Review my header post. I just put them in with minimal problems.
Old Jan 23, 2004 | 11:09 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Install question on headers- help. (Bobchad)
no brackets or anything are needed...
read my posts on my install, if you have any questions I let me know. http://forums.corvetteforum.com/zerothread?id=557102 http://forums.corvetteforum.com/zerothread?id=557836 http://forums.corvetteforum.com/zerothread?id=558513
Old Jan 23, 2004 | 11:14 PM
Shark Racer's Avatar
Shark Racer
Imoth- You'll need a spacer for the bolt that goes to the bottom of the AC compressor, to make up the difference between the exhaust manifold and the header flange. Other than that, you're good to go.
-Steve
Old Jan 24, 2004 | 12:06 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Install question on headers- help. (Pacin'California)
-Steve
:iagree:
And use Stage 8 locking header bolts.
Old Jan 24, 2004 | 12:43 AM
Metal Wulf's Avatar
Metal Wulf
-Steve
he doesn't need one... if he wants to add one he can, but it's not something you have to do.
Old Jan 24, 2004 | 12:48 AM
Shark Racer
Default Re: Install question on headers- help. (Metal Wulf)
I know that the guys on the forum told you that that bottom bracket isn't necessary, but a 25 cent piece of metal isn't a big investment on one of the accessories that pulls a very large draw on its pulley, not to mention has some pretty sharp acceleration rates...
-Steve
Old Jan 24, 2004 | 12:54 AM
Disco_Mike's Avatar
Disco_Mike
an agreement on the spacer for the A/C bracket. If you have a standard tranny, you'll have to remove the clutch rod assy. the asembly has one side connect to the frame rail and the other to the block. once the header is in place the assy goes between tubes 5 and 7 (or is it 6 and 8?)
Old Jan 24, 2004 | 08:01 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
Put the spacer tube on between the header flange and the A/C bracket. Don't 1/2 azz the install.
Old Jan 26, 2004 | 11:39 AM
Imothph's Avatar
Imothph
Default Re: Install question on headers- help. (BSeery)
Thanks all, great info. Im used to tweeking, grinding, spacing and otherwise raiding coffee cans of bolts and weashers to make things fit - sounds like this should be a fairly easy install. ( heavy on the "should be").
I'll let ya'll know if I make it out alive.
To Install question on headers- help.
