Knocking or pinging sound
Old Jan 24, 2004 | 01:03 AM
Clown Puncher's Avatar
Clown Puncher
Default Knocking or pinging sound
71 350 with alot of motor mods. Has a loud knocking sound that moves with rpm. It does have an aftermarket comp cam in it and the motor has only about 14,000 miles on it since everything was replaced 9 except the block). I have not noticed any power loss, but I can hear the difference even from the exhaust. in the morning I am going to get a compression test to make sure. Anyone have any ideas? :confused:
Old Jan 24, 2004 | 02:02 AM
Corey_68's Avatar
Corey_68
Default Re: Knocking or pinging sound (Clown Puncher)
Have you checked the timimg, it may have moved. Maybe you got ahold of some bad gas to cause the pinging? :confused:
Old Jan 24, 2004 | 09:35 AM
Surfer69's Avatar
Surfer69
Default Re: Knocking or pinging sound (Corey 68)
Use screwdriver to ear trick and listen around different areas of the engine to isolate the noise source. If knocking inside engine, could be spun bearing or other possible things.
To Knocking or pinging sound
