Timing lights
Old Jan 24, 2004 | 06:14 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Timing lights (Guru_4_hire)
when i bought my balancer cover a few years ago i believe it was 35 bucks if i remember right.
your gonna have to remove the pully from the crank though. Three bolts. Should be about a 30 min job.
[Modified by turtlevette, 6:21 PM 1/24/2004]
Old Jan 24, 2004 | 06:24 PM
Paul L's Avatar
Paul L
A high-quality timing light is much more than a flashlight. Buy a good one and it will serve you well for many years.
Old Jan 24, 2004 | 07:29 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I like the new light from Equus but haven't bought or tried one yet. For $100 at Pep-Boys it has a built in tach with dial back timing for setting advance curves by changing springs and weights. Also has xenon bulb. I don't know how accurate it is but a built in tach will make timing chores much much easier.
Now for power there is a hot positive post on my '74 drivers-side fender and easy to find as a bunch of red wires connect to it. Any engine metal ground will do for the negative.
Let us know if you use this one. Happy hunting. cardo0
