Does side exhaust restrict flow and kill power?
Old Jan 24, 2004 | 09:41 PM
79VetteMike's Avatar
79VetteMike
Default Does side exhaust restrict flow and kill power?
I've been running 2.5" duals and Flowmasters, but am possibly considering side exhaust. I've heard that they rob power. Any thoughts?
Old Jan 24, 2004 | 09:46 PM
LFZ's Avatar
LFZ
Default Re: Does side exhaust restrict flow and kill power? (79VetteMike)
depends on the setup..if you go with Hookers, it shouldn't be a problem, just run them straight flow...if you go with 69 style factory setup...might be a problem, unless you spend mucho $$$ for bigger diameter pipes to fit under the covers.
Old Jan 24, 2004 | 10:49 PM
71vetteLT-1's Avatar
71vetteLT-1
what do most ppl looking for power but want to keep the 69 side covers do? as far as piping/mufflers and headers go?
Old Jan 24, 2004 | 10:55 PM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
You can pretty much expect to lose power anytime there is a 90 degree bend in an exhaust system.
Old Jan 24, 2004 | 11:08 PM
1Bad69's Avatar
1Bad69
Default Re: Does side exhaust restrict flow and kill power? (theanswriz42)
even when it collects to a 4" pipe?
Old Jan 24, 2004 | 11:18 PM
theanswriz42
Default Re: Does side exhaust restrict flow and kill power? (1bad69)
I don't really know to be honest with you but typically straight exhaust will yield better HP and torque numbers from what I've seen. I am definitely not an expert on sidepipe exhaust though so I probably am not a good person to ask that. You probably know more about that stuff than I do seeing as you have sidepipes :seeya
Old Jan 24, 2004 | 11:56 PM
79VetteMike
By the way, I already have the Dynomax Ceramic coated headers, so if I get side pipes, they will have to hook up to the headers I already have. Thanks again.
Old Jan 24, 2004 | 11:58 PM
Rockn-Roll's Avatar
Rockn-Roll
My L48 came out of the factory with 165HP at the flywheel. Now it has 200HP at the rear wheels...only change is sidepipes. You do the math.
Old Jan 25, 2004 | 01:30 AM
Chuck Harmon's Avatar
Chuck Harmon
Just like an under car system, it depends on what you have. I only lost 6hp from my high of 483rwhp using the JCL spiral baffles. If I had spent any time adjusting the a/f ratio change from open to JCLs, I honestly believe I would have gotten all 6hp back.
The JCLs do a very good job keeping the car reasonably quiet, but they also let the engine breathe. Ground clearance is my biggest reason for going to the Hooker sidepipes.
Chuck
Old Jan 25, 2004 | 02:00 AM
1979toy's Avatar
1979toy
I don't know of any sidepipes that will connect up to long tube headers without having to make a U turn in the exhaust system. If you have the shorty style of header then you can connect the factory style sidepipes up without too much fabrication.
Any sidepipe is going to at least seem louder than an under car exhaust simply due to the fact that the exit for the pipes is directly under your ear by about 4 feet.
Old Jan 25, 2004 | 06:40 AM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: Does side exhaust restrict flow and kill power? (1979toy)
Less than 4'...I can open the door and reach out and feel the exhaust flow, and I know my left arm is not 4' long. Sidepipes are louder because of that and you will also want to drive with the windows down to maximize the effect! :D
Old Jan 25, 2004 | 07:09 AM
garandfan's Avatar
garandfan
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Default Re: Does side exhaust restrict flow and kill power? (Rockn-Roll)
:iagree:
Old Jan 25, 2004 | 07:47 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Don't forget, your '75 came from the factory with a 2 into one exhaust thru a restrictive cat. :yesnod:
Old Jan 25, 2004 | 07:20 PM
American Boy's Avatar
American Boy
Keeping your headers will complicate the tubing and you'll probably lose some flow capacities from the 90 degrees. The best way to go are the Hookers sidepipe with JCL baffle. Otherwise, a dual system with a X or H-pipe will surpass any sidepipe system...unless you run an X-pipe with sidepipe as the Nascar does. They are awesome. :eek: :D
Stephan
Old Jan 26, 2004 | 01:34 AM
Turbo-Jet's Avatar
Turbo-Jet
really??? you went from ~140 rwhp to 200? all else the same on stock a L48? wow! :crazy:
Old Jan 26, 2004 | 07:44 AM
groovyjay's Avatar
groovyjay
I'm taking my 79 to chassis dyno as soon as the snow melts and I can actually drive the car again. I will try what kinda power difference is between open headers vs open sidepipes vs sidepipes with baffles.
I also highly recommend baffles so far, relatively quiet but yet not too restrictive. :cheers:
Old Jan 26, 2004 | 10:02 AM
lvrpool32's Avatar
lvrpool32
I've nearly finished fabricating a 3" stainless system that fits under the stock factory sidepipes. (connecting to headman factory sidepipe headers)
The headers need a bend of 50 degrees to flare out to the side pipe tubes, and the tube is all 3".
I have to believe that the factory pipes at 2" down to 1-3/4" in the muffler where restrictive.
I will have to wait and see if the difference is "seat of the pants" noticeable
or wether its just dyno numbers.
Nick
Old Jan 26, 2004 | 10:51 AM
tnt76vette's Avatar
tnt76vette
Default Re: Does side exhaust restrict flow and kill power? (lvrpool32)
I haven't posted here in about six months, but this seems to be the question that never dies, because it has never been proven either way. When I rebuilt my '76 I went with chambered pipes (same set up as sidepipes but exit out the rear. The sound was awesome! My ONLY beef about side pipes is the burnin' leg issue.....but they do sound great! Last question: When do we just start enjoying our cars instead of wondering about that 1/4 of a horsepower we lost/gained by our selection of a certain component? ENJOY!! :D :cheers:
To Does side exhaust restrict flow and kill power?
