Headers
Old Jan 25, 2004 | 10:06 AM
Mike71's Avatar
Mike71
Default Headers
What headers fit best, work with Mid Americas true duel for 79 L82?
Mike
Old Jan 25, 2004 | 10:50 AM
Mike71's Avatar
Mike71
Default Re: Headers (Mike71)
no one with headers??
Old Jan 25, 2004 | 11:06 AM
GDaina's Avatar
GDaina
Mike
I don't think you can take a set of headers out of the box and expect a perfect fit....I found that you have to fiddle with the bolt holes...use the header gasket to check the holes on the flange.
Another thing to consider, emissions testing.....you may not pass if you bypass the cat.
Old Jan 25, 2004 | 11:09 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
I have a set of dynomax ceramic coated headers sitting in my garage waiting for me to start install tommorrow. I'll let you know how it goes. I have read several others who said they went on without a hitch. :cheers:
Old Jan 25, 2004 | 11:49 AM
Mike71's Avatar
Mike71
Default Re: Headers (brooksman9)
brooksman9, please post how it went, that's the ones i'm looking at, we dont have e-check where I live so cats are going also!
Old Jan 25, 2004 | 12:05 PM
Fevre's Avatar
Fevre
Many are using the dynomax ceramic coated headers and most a very happy with them. You will probably have to do some fitting to get the Mid america system to work so might be better to just take it to a good exhaust shop and have them fab up a complete system from the headers back for ya. I have mine all rig up and once I have selected a 5 speed trans and it is installed I will move onto the exhaust system.
Old Jan 25, 2004 | 02:42 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: Headers (Fevre)
I got Hooker Headers for Christmas (non-ceramic) but I left them in NC as they didn't fit in my car. I'll be installign those this summer. Anyone have fit experience with those?
Old Jan 25, 2004 | 04:08 PM
Bobchad's Avatar
Bobchad
Default Re: Headers (RUXperienced)
Just put the Dynomax ceramic coated on. Perfect fit.
Old Jan 25, 2004 | 04:32 PM
brooksman9's Avatar
brooksman9
Default Re: Headers (Bobchad)
glad to hear that :hurray: . I also got aset of Hooker header back pipes from summit specifically for these years. that way I can bolt the whole thing on and then take and just get welded up. Don't have to ask or pay anyone to put on pipes that aren't supposed to be on anyway. I ordered Hookers Areo Chamber mufflers from summit also but have not gotten them yet.
Old Jan 25, 2004 | 04:37 PM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
I have hooker 1-5/8" hooker headers on my car, they work wonderfully :seeya
Old Jan 25, 2004 | 05:19 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Headers (theanswriz42)
Headman headers -- 68300 or 68301 (ceramic coat) fit my 1980 perfectly. You will have to have some custom work done to get the exhaust to match up to the headers, and if you have A/C you will have to make a spacer for the first bolt on the passenger side.
Really easy and clean install.
Old Jan 25, 2004 | 05:46 PM
LFZ's Avatar
LFZ
got Hooker Super Comps on the 74...fits great, but hangs alot lower than most headers, may hit some speed bumps or drag going up some inclines...but they are by far the most free flowing full tube headers out there.
Old Jan 25, 2004 | 06:01 PM
theanswriz42
Default Re: Headers (Redshark6974)
I can vouch for that as well. You have to take speed bumps really slowly and be careful of how high they are. I think I have about 3-4" ground clearance with my headers.
Old Jan 26, 2004 | 12:39 PM
brooksman9's Avatar
brooksman9
Mike,
Headers went on very easy. Remove starter and spark plugs. My compressor is already gone. After that, install from bottom and boly up. Working on pipes now.
Old Jan 26, 2004 | 12:59 PM
Disco_Mike's Avatar
Disco_Mike
I had an exhaust shop custom bend tubes for the headers 20 years ago.
Old Jan 26, 2004 | 02:17 PM
brooksman9's Avatar
brooksman9
Default Re: Headers (79Fever)
prebent pipes didn't fit. spoke to hooker and they said they had had some problems with some older pipes and were warrantying them. called summit and they said to send them back and would send another set plus pay for return shipping. gotta love those guys at summit. hate that they didn't fit though. and of course i just had to fire it up and hear the open headers. :cool:
Old Jan 26, 2004 | 02:29 PM
thevetterisbetter's Avatar
thevetterisbetter
Dynomax went in easy enough, but don't line up with the rest of the exhaust too well.
Old Jan 26, 2004 | 02:42 PM
Lit-Bern's Avatar
Lit-Bern
Default Re: Headers (thevetterisbetter)
I put on a set of Holley flowtech ceramic coated full length. I love them but there was a lot of custom fitting "cads and cheater pipes" between the headers and the cross member to keep it legal. all flanged for easy change outs.
Old Jan 26, 2004 | 03:15 PM
fauxrs's Avatar
fauxrs
Default Re: Headers (BSeery)
Me too...Hedman makes headers that will be accepted for smog in CA...even though they dont have an E.O. Number for my application - my engine has been smogged twice withthese headers on.
Here is a image from the drivers side.
The only thing I had to do was put a small dimple in one tube to clear the idler arm boot. Installation took an afternoon. Hook up to factory dual exhausts wasnt all that difficult using Hedman extensions.
To Headers
