72 Spare Tire Carrier ?
Old Jan 27, 2004 | 12:14 PM
cdc's Avatar
cdc
Default 72 Spare Tire Carrier ?
I need to refinish an original spare tire carrier tub for a 72. Is there a correct
color for the outside of the tub- flat black, semi gloss black or something
else?
Thanks, CDC
Old Jan 27, 2004 | 12:42 PM
markdtn's Avatar
markdtn
Default Re: 72 Spare Tire Carrier ? (cdc)
I think it's semi-gloss, but you might check the NCRS site.
Old Jan 27, 2004 | 12:59 PM
gerry72's Avatar
gerry72
It is natural, unfinished fiberglass. The metal strips are painted but you'll need NCRS opinion on the particular finish.
Old Jan 27, 2004 | 01:57 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
Gerry's response is correct.
The fiberglass "tub" is natural... For your 1972 Corvette, it is the dark "black" fiberglass with distinct strands running through the material, not the grey SMC tub that was used in later years. There may or may not be overspray from the muffler blackout on the edges of the tub nearest the exhaust, but this was an issue of sloppy blackout application rather than any attempt to paint the tub itself.
The metal support is painted semi-gloss black. the rivets attaching the support to the tub are natural aluminum.
Regards,
Old Jan 27, 2004 | 04:26 PM
cdc's Avatar
cdc
Default Re: 72 Spare Tire Carrier ? (Rowdy Rat)
Thanks for the response. If my original carrier has been spray painted- have you seen any product that can safely remove the paint without damaging
the fiberglass and get it back to the original surface?
Thanks, CDC
Old Jan 28, 2004 | 01:36 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Try lacquer thinner or enamel reducer. See if that will remove the paint. They were "natural", as others have stated. Chuck
Old Jan 28, 2004 | 05:03 PM
Solid LT1's Avatar
Solid LT1
Default Re: 72 Spare Tire Carrier ? (Chuck Gongloff)
Castrol "Super Clean" will lift most paint without hurting the raw fiberglass (will also dry out skin rapidly! when not protected by gloves and being used in undilluted state!) You may get lucky and find original North American Rockwell emblem inlaid into the fiberglass of tire carrier (also found one in fender of my 72 LT-1 Vette-never been wrecked but, has been raced!) This is the same company that made aircraft such as P-51/F-86 Sabre to B1-B bomber (could this be why my car is so fast?)
To 72 Spare Tire Carrier ?
