Advice needed on rust/frame repair!
Old Jan 27, 2004 | 01:09 PM
Daleford's Avatar
Daleford
Default Advice needed on rust/frame repair!
We have a 69 in our shop with a rust problem at the rust prone area. That being where the rear trailing arms bolt to the frame. I can almost repair it from the rear and underside, but here is my question....
is it possible to cut an access hole in the floor from the passengers compartment and do some repairs to the top of the frame? We don't really want to lift the body! :confused:
Old Jan 27, 2004 | 01:35 PM
Stewart's74's Avatar
Stewart's74
Default Re: Advice needed on rust/frame repair! (Daleford)
Do yourself a favor and lift the body. Rest assured, if you have rust in one area you've got it in others.
Old Jan 27, 2004 | 01:38 PM
Disco_Mike's Avatar
Disco_Mike
Default Re: Advice needed on rust/frame repair! (Stewart's74)
Sounds like good advice. It the frame is that bad, you can purchase remanufactured frames.
Old Jan 27, 2004 | 01:46 PM
frank0075's Avatar
frank0075
Default Re: Advice needed on rust/frame repair! (79Fever)
I agree!!
Old Jan 27, 2004 | 11:03 PM
Tired74's Avatar
Tired74
There is a metal frame inside of the fiberglass that overlays the actual car frame. Cutting through the glass may not give you the access that you want. Lifting the body will give you an opportunity to inspect and repair the frame as well as the birdcage inside the fiberglass. Don't scrimp on frame repairs. My car was "restored" by previous owners and sold to me after it broke in half because only the bottom were repaired. I can email some pictures of the rust you can expect but cannot see with the body on. The pictures are too large for posting.
Old Jan 28, 2004 | 08:39 PM
John 65's Avatar
John 65
Have to agree with everybody. Better safe than sorry...............I would hook up the straps.
Old Jan 28, 2004 | 11:09 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Yank it. Chances are pretty good the rocker channels are all rotted out as well. Be real careful lifting from them if you are not sure, straps that go all the way under are safer then picking the body with a "lift kit" that grabs it by the channels.
Old Jan 29, 2004 | 08:07 AM
Daleford's Avatar
Daleford
OK Guys, I thank you all. We will plan the lift. Is there anywhere on the net that describes how to do that? I've done a lot of automotive stuff but not that. THANKS again. Dale
To Advice needed on rust/frame repair!
