Break calipers, another stupid question.
Old Jan 27, 2004 | 07:20 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Default Break calipers, another stupid question.
My bleeders are frozen, I have soaked them in penatrating oil for the last week. They are still frozen. Is there a kit I could get to drill and tap them with? Or would it be easier to hone the centers out until I can get a small punch in there and bend the bleeder thread loose from the caliper thread?
:confused:
Old Jan 27, 2004 | 07:21 PM
79VetteMike's Avatar
79VetteMike
Default Re: Break calipers, another stupid question. (wackedvette)
Can you get a deep socket on them?
Old Jan 27, 2004 | 07:25 PM
wacked's Avatar
wacked
Default Re: Break calipers, another stupid question. (79VetteMike)
There rounded off. There stuck in there real bad. I tryed a tourch to. :banghead:
Old Jan 27, 2004 | 07:27 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I replaced mine with Speed-bleeders last week. At least 3 of them rounded off and I had to get a vice-grip on them, which worked out...except for one, which snapped off. Now I have a bit of a problem, but I may be able to get it out with a screw extractor. Other than my experience, I dunno what to tell you. Just be careful with things that have a tendancy to turn a problem into a bigger one! And convert to Speed-Bleeders if you weren't already going to! They are great.
-Chris
Old Jan 27, 2004 | 07:32 PM
blue427's Avatar
blue427
Try putting a vice grip on it [make it very tight] tighten it a little first then try backing it out. If that does't work cut off the top of the bleeder with a cut off wheel, drill a small hole and use an easy out. :seeya
Old Jan 27, 2004 | 07:37 PM
wacked's Avatar
wacked
Default Re: Break calipers, another stupid question. (RUXperienced)
Thanks guys:) Tell you what it was a PITA to get the calipers off.
I had to battle with 3 big spiders, I hate spiders. :eek:
I'll try the vice grips, I want to drive this thing this summer.
Old Jan 27, 2004 | 07:49 PM
LiveandLetDrive
Spiders are only good for -> :smash:
I forgot to mention, the one I broke off broke because I was using vicegrips, be careful not to crush them, they are hollow as I discovered. (Also means you don't have to drill for an easyout, there's a hole almost as big as the thread-size.)
Old Jan 27, 2004 | 07:57 PM
Wrecked82's Avatar
Wrecked82
Just be careful not to break your brake calipers, or is it brake your break calipers, or broke your ... oh forget it.
79VetteMike
If the vice grips or easy out doesn't work, drill through the bleeder leaving only the threads left. The remaining metal should be thin enough to tap it out with a hammer and awl.
Old Jan 27, 2004 | 08:24 PM
wacked's Avatar
wacked
Default Re: Break calipers, another stupid question. (Larry82)
I will be very careful.
Old Jan 27, 2004 | 08:27 PM
wacked's Avatar
wacked
I'll post a link to the pics when I do this:)
This car is driving me crazy.
Old Jan 27, 2004 | 08:49 PM
71vert's Avatar
71vert
I just had the same problem, keep heating with the torch,thats the only way I found to get them out, make sure its red hot!!! all the way through before you try to turn them other wise you will snap off the tops.
Good luck
Old Jan 27, 2004 | 09:50 PM
LiveandLetDrive
Default Re: Break calipers, another stupid question. (71vert)
Are you talking about heating the bleeders?? Heating causes expansion you know... that might break the rust seal somehow, but even then you should wait until it's cool. Heating the calliper might be a little difficult, but that's what would work.
-Chris
Old Jan 28, 2004 | 01:14 PM
Solid LT1's Avatar
Solid LT1
HEAT EM UP! if you don't have an Oxy/Acetelyne unit, buy a Mapp gas plumber's torch at ACE Hardware and use it. When hot you can "shock" them with liquid wrench or other liquid lube (careful about spray can type, use oil can type, otherwise you are on your own!) This works 99/100 times, otherwise you should probably just buy reproducton caliper as machine shop will want over $25 to EDM out broken bleeder screw (at least in my area of the US.)
To Break calipers, another stupid question.
