Cracked Ignition Coil
Old Jan 27, 2004 | 11:03 PM
mstanton's Avatar
mstanton
Default Cracked Ignition Coil
Yes my name is Bubba. I managed to crack the plastic top of the ignition coil on my 71 with TI and now it is bleeding what appears to be oil. Is there oil inside ignition coils? Can a damaged coil be rebuilt/repaired? This is the original coil which came with my 71 LT-1 and I would like to salvage it. Thanks.
Old Jan 28, 2004 | 12:36 AM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: Cracked Ignition Coil (mstanton)
Salvageable no way. Inexpensive? Yes they are unless you run an expensive aftermarket super coil. Ecklers has stock units to be had for less than $30.
David
Old Jan 28, 2004 | 01:34 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Not familiar with your year, but if you have the original coil with the embossed numbers "271" 12V, etc., you can buy a repro from Goat Hill. They're about $100.00 as I recall. Goat Hill is owned by Paul Baker. His eMail address is goathil@aol.com ONE L in Goat Hill in the address. Chuck
To Cracked Ignition Coil
