Looking for advice on Heads..
Old Jan 28, 2004 | 07:13 PM
SilveroverBlue81's Avatar
SilveroverBlue81
Default Looking for advice on Heads..
After much thought I think I will replace the heads (forgo the timeing gear and under pully), I will have to admit this is uncharted territory for me. I want something that will give me decent power but not mind hiway driving. I have automatic transmission with a shift kit and stock rear end. I would rather not change the rear end just yet if I don't have to. If anyone could give me some insite on what different setups might do I would be in your debt.
I have the cam and the rest figured out, thanks.
1981, 350 L81--Automatic-- :withstupid:
Old Jan 28, 2004 | 07:36 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Looking for advice on Heads.. (SilveroverBlue81)
Sportsman II heads are very good and not as expensive as aluminum, I got some serious power out of them :D
[Modified by MotorHead, 6:37 PM 1/28/2004]
Old Jan 28, 2004 | 10:51 PM
marshrat99's Avatar
marshrat99
I'm using Dart Iron Eagle 180 heads. I'm told there's not much difference between these and World's. Not knowing what cam you've decided upon, I can't comment on what size you really need. Anyway, the Darts I bought were already assembled and have stainless valves. These are available at either Summit or Jeggs. While you're at it, you might want to upgrade your intake. The guys at Summit or Jeggs will be glad to give advise on matching your heads, intake and cam for you. However, these are not smog heads and might be a problem if you're wanting to keep your smog stuff. :cheers:
Old Jan 28, 2004 | 11:07 PM
Eric R's Avatar
Eric R
Default Re: Looking for advice on Heads.. (marshrat99)
Ditto on the Dart Iron Eagles!
I run the 72cc chamber, 200cc runner heads myself and love 'em
:iagree:
Old Jan 29, 2004 | 08:05 AM
SilveroverBlue81
Here are the mods i have planned...
Comp Cams Magnum Roller Rocker Arms
Edelbrock Performer (EGR) 3706 Intake manafold
Comp Cams High Energy Hydraulic Lifters
Comp Cams Magnum Pushrods
Competition Cams 268 High Energy Camshaft
HEI Super Coil
Steward Hi-Flo Small Block Aluminum Water Pump
Hypertech Thermo Master Power Chip
:cool:
Old Jan 29, 2004 | 08:10 AM
PatsLs1vette's Avatar
PatsLs1vette
im also happy with my sportsman 2's i lost alittle low end when i had them on my carbed motor but really helped out on my injected motor.
Old Jan 29, 2004 | 08:50 AM
Ganey's Avatar
Ganey
Default Re: Looking for advice on Heads.. (patsnitrovette)
170-180 would be very good for your setup.
To Looking for advice on Heads..
