What cam to install
Old Jan 28, 2004 | 11:59 PM
Clown Puncher's Avatar
Clown Puncher
Default What cam to install
Does anyone have advice on what cam to install into a 71 350 .030. It has low mileage and flathead pistons, holley 650 dominator, edelbrock 7500 performer and a few other mods. The kicker is that the rear gear is 3.08 and I have the 3 speed auto. I can get a great deal on a comp 282 cam, but I am not sure what to expect from this cam with my setup. Any advice would be greatly appreciated. :confused: :confused: :confused:
Old Jan 29, 2004 | 12:33 AM
comp's Avatar
comp
Default Re: What cam to install (Clown Puncher)
IMO it's a little to much for stock convertor, and 308's 2cents :cool:
Old Jan 29, 2004 | 12:53 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: What cam to install (comp)
268 is a bit steep for the stock converter and 3.08 gears, so the 282 is WAY too much :iagree: . You will have nice top end power, but no grunt to get off the line. Try something between there and a 260. Try something with a split duration that give more duration and / or lift to the exhaust side as well. look at the cams with a 210 intake and 216 duration (at .050 lift). That would be the biggest I could see doing with a stock converter.
[Modified by BSeery, 9:54 PM 1/28/2004]
Old Jan 29, 2004 | 08:52 AM
Ganey's Avatar
Ganey
Comp Cams XE-256 would be very good for your setup.
Old Jan 29, 2004 | 12:44 PM
marshrat99's Avatar
marshrat99
I'm running a 355, Elderbrock Performer ESP intake, Dart Iron Eagle 180's, and Holley 670 carb. My cam is Comp XE262 and think it is just perfect. I'm also using a B&M 2500 stall but don't need it. The big question is what kind of rear ratio am I using. Mine is a bone-stock 79. Anybody have any ideas on my ratio? If it turns out to be the same as your's, then I'd say go for the XE262 or 268.
BTW, my idle is a smooth 900RPM in park and 650 in drive. Plenty of vacuum.
[Modified by marshrat99, 12:45 PM 1/29/2004]
Old Jan 29, 2004 | 01:08 PM
CaptainMike's Avatar
CaptainMike
Default Re: What cam to install (marshrat99)
If it was a '79 L-48 then it has 3:55 rear gear....
Old Jan 29, 2004 | 03:11 PM
marshrat99's Avatar
marshrat99
Default Re: What cam to install (CaptainMike50)
CaptianMike: My 79 is an L82
Old Jan 30, 2004 | 01:02 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
ISKY! For max torque use Iskenderian 262-SUPERCAM, HYDRAULIC or maybe 264-MEGA, HYDRAULIC. :thumbs:
To What cam to install
