ZZ4 Install
Old Jan 30, 2004 | 11:25 PM
gr8t73's Avatar
gr8t73
Default ZZ4 Install
I am in the process of installing a ZZ4 Crate Engine in my 73. I plan on installing the stock cowl induction air cleaner with the stock hood, can anyone tell me if I will have clearance problems with this set up? :banghead:
Old Jan 30, 2004 | 11:31 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: ZZ4 Install (gr8t73)
I've got a ZZ4 in my stock 69 and the stock aircleaner fits fine under the SB hood. The only advice I can give is install the ZZ4 and trial fit the air cleaner and hood.
I have an L88 hood, Air cleaner and box, that I have mocked up on the car, it fits perfectly on top of the ZZ4 manifold and either a Qjet or a Holley.
Old Jan 31, 2004 | 09:31 AM
Chuck-75's Avatar
Chuck-75
Default Re: ZZ4 Install (Smokehouse69)
Gr8r-73 , Pls keep me informed on how the install goes?, Im planing on doing the same this summer with a 4spd auto. (havent got all the info on eighter to go with a 200r4, or the 700r4?), Ive got a 75 vert and also had the same question about if I could be able to still use the same carb filter and have the hood intake still function?, :seeya
Old Jan 31, 2004 | 09:56 AM
theandies's Avatar
theandies
I wrote this some time ago for ZZ4 swaps https://www.corvetteforum.com/techti...=167&TopicID=3
Old Jan 31, 2004 | 08:11 PM
gr8t73's Avatar
gr8t73
Default Re: ZZ4 Install (theandies)
I am in the process of doing a frame off restoration on my 73 so far I have had the frame blasted and painted, installed front and rear suspension, zz4 motor & TH400 transmission installed, have quite a bit of work to do on the body before I drop it back on the frame. I have the original motor on a stand thought the ZZ4 would be nice change. I had the ZZ4 in my 77 at one time and I had to use an aftermarket air cleaner due to clearance problems. I beleive the 73 hood may have enough clearance will let you know but it may be a while. The ZZ4 is a sweet engine. :steering:
To ZZ4 Install
