NOISE FROM OIL PAN
Old Jan 31, 2004 | 02:48 PM
Oldguard 7's Avatar
Oldguard 7
Default NOISE FROM OIL PAN
When the vette is ldling there is a rapping sound coming from the front of the oil pan. I placed a stethoscope at the bottom of the oil pan with the engine running. The sound occurs about every 5-6 seconds. It sounds like the counterweight is hitting the slanted portion of the oil pan. If i'm wrong, could it be that a main bearing has spun?
Old Jan 31, 2004 | 03:29 PM
comp's Avatar
comp
Default Re: NOISE FROM OIL PAN (Oldguard 7)
???? pull the dip-stick out a few inch's and see ig it changes :eek:
Old Jan 31, 2004 | 04:56 PM
carl a's Avatar
carl a
Default Re: NOISE FROM OIL PAN (comp)
i had a similar noise coming from oil pan in my old gmc safari and when i dropped the pan and pulled off a few bearing caps the babbit was gone from the bearings giving it too much clearence and the noise was the crank wobbling-----------
Old Jan 31, 2004 | 05:41 PM
78 Vette's Avatar
78 Vette
Default Re: NOISE FROM OIL PAN (carl a)
check the timing chain cover the same way you checked the oil pan it might be a stretched timing chain hitting the cover. I have seen this happen Just a thought.
Old Feb 1, 2004 | 02:32 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Maybe that mouse is just get'n hungry. :jester
To NOISE FROM OIL PAN
