TH400 rebuild fixture
Old Feb 1, 2004 | 01:09 PM
GTR1999's Avatar
GTR1999
Default TH400 rebuild fixture
I was looking for a used Kent-Moore tranny holding fixture to rebuild my TH400. Ebay had some for $150-200 which seems a lot for a big C clamp.
I went to Homo Depot and bought the Chinese black pipe and fittings they sell,you know the ones with threads that aren't perpendicular to the hole.
Well for about $30 and the use of my 120v mig welder I made a fixture that works the same as the KM one and mounts to an engine stand. I can rotate it 360* to get at any part of it.
I used 1" black pipe and fit the end into 1.250" pipe like an engine stand works. I did have to turn ends from steel to fit the tranny casting boss.
I have it holding the tranny now. To test it I'm going to leave it on the stand overnight with a sling as backup. If anyone is interested let me know and I'll give you the info.
As you might as surmised, I don't care for the imported products I found at the store. I don't know anyone uses them for gas or air lines? What do we make here(USA) nowadays?
Gary
Old Feb 1, 2004 | 02:00 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: TH400 rebuild fixture (gtr1999)
Over at turbobuick.com there are a few guys that made their own trans holder. Doesn't seem too hard.
Old Feb 1, 2004 | 02:09 PM
comp's Avatar
comp
Default Re: TH400 rebuild fixture (427V8)
i can use the info :thumbs: :thumbs: going to check out t-buick also
Old Feb 1, 2004 | 02:37 PM
comp's Avatar
comp
Default Re: TH400 rebuild fixture (comp)
A pic would be nice if you can, thanks :flag
Old Feb 1, 2004 | 06:52 PM
GTR1999's Avatar
GTR1999
I'll see if I can get a picture. I don't have a digital camers but can scan photos. I should have them back in a week.
It does work, I came back to the shop and ripped the tranny down to the point where I need a 3/8 12 pt socket to remove the rest of the main shaft. Of course I didn't have a socket here to fit it :rolleyes:
I was able to rotate the tranny 180* to remove the valve body no problem.
Gary
Old Feb 1, 2004 | 08:28 PM
comp's Avatar
comp
THANKS we'll be waitin' :thumbs: i can't even scan :nonod:
Old Feb 10, 2004 | 04:52 PM
GTR1999's Avatar
GTR1999
Comp, I got some pictures in are you still interested?
Gary
Old Feb 10, 2004 | 04:59 PM
comp's Avatar
comp
ya' pic away :thumbs:
Old Feb 10, 2004 | 05:11 PM
GTR1999's Avatar
GTR1999
OK I'll send them in a few.
Gary
Old Feb 10, 2004 | 05:49 PM
comp's Avatar
comp
got THANKS so simple it's cool :thumbs: tried to email back :confused: i
crashed, i may be able to screw it together and not need to weld....
i'm also thinking camo paint :thumbs: thanks again :flag
Old Feb 11, 2004 | 11:22 AM
GTR1999's Avatar
GTR1999
Yeah you can build it without welding except for the braces I added in. Also look to see where the pins go into the tranny I made these on a lathe. I used tool steel and tapped the ends 7/16-14. One side is fixed the other is threaded rod to adjust it on. Stay with 7/16 or go up to 1/2 rod. Another idea I had was to use a couple of C clamps and cut and weld them in as screws. The threads are acme and hold better then the 60* V threads of the all thread. You'll have to figure a way to do that or have someone make them up for you. Those are the first pictures after I gutted the tranny I removed the case to polish it and painted the fixture with a gold paint I had in the cabinet.
Gary
Old Feb 11, 2004 | 11:39 AM
Bill Oxley's Avatar
Bill Oxley
Gary, I'm going to be doing one soon too. Would you mine sending me a couple of the pics too.
Would be much appreciated, Tnx, Bill (bill@billoxley.com)
Old Feb 11, 2004 | 12:58 PM
GTR1999's Avatar
GTR1999
Default Re: TH400 rebuild fixture (Bill Oxley)
Sure on the way Bill. Let me know if you have any questions.
Gary
Old Feb 11, 2004 | 05:08 PM
comp's Avatar
comp
just got back up to here, thanks probably start collecting pipe this weekend.
gold does sound good for this project, then i found a can of COPPER :eek:
way cool :thumbs:
Old Feb 11, 2004 | 05:12 PM
GTR1999's Avatar
GTR1999
:thumbs: nothing to it but to do it!!
Gary
To TH400 rebuild fixture
